BOLT THREAD REFERENCE!
srtthis
the guy doing it does every local racers rear end
5,114
1,656
204
Maryland
since there has been plenty of talk... and no doing it...
intake manifold
5/16-18 x 2.5
valve cover
1/4-20 x 1
Crank pulley
3/8-16 x 1
Plugging Smog Hole (thermactor plug) 5/8-11
speed sensor clamp
1/4-20 x 3/4
Tps sensor screws
M4 x 0.7 pitch x 25mm length
intake plaque
8-32x1/2" taper seat machine screw
For those who need to plug their low oil level sensor hole
Oil plug M20 1.5 thread pitch
Edelbrock performer and typhoon upper plenum cover-
1/4x1 machine cap screws are a direct fit
Edelbrock performer and typhoon upper to lower studs-
5/16x1-3/8 carb studs.
Thermostat housing
5/16-18 x 1 3/4" for top left bolt
5/16-18 x 1 1/4" for bottom right bolt
Both bolts use split lock washers.
Battery hold down bolt
6mm x 1.0 x 55mm
87+ Wiper motor screw: 1.25" long blunt sheet metal screws. 1/4"-14 thread
Rear Shock 12mm x 1.75 x 70mm or you can use a 1/2" x 1.50" long bolt.
Quad shock axle housing mounting bolts(12mm x 1.75 x 70mm)
add what you have... we get a good amount i will put it in excel and put the torques and such also!
mods please sticky!
Edelbrock performer and typhoon upper plenum cover- 1/4x1 machine cap screws are a direct fit
Edelbrock performer and typhoon upper to lower studs- 5/16x1-3/8 carb studs.
Water pump bolt kits - See Totally Stainless for replacement stainless steel bolts. Last time I checked, they didn't have the studs. Nice folks, very into cars of all types. They have all kinds of stainless fasteners for almost every car. The prices are very reasonable, less the $10 for the water pump kit without the studs.
Water pump stud kit
The studs are a Motormite item available at your local Advance Auto Parts store.
Motormite Water Pump Stud Kits for Ford, Lincoln and Mercury cars and trucks w/3.8L, 4.6L, 5.0L, 5.8L.
Part Number: 23744
Got the water outlet bolt sizes thanks to a guy on Corral
Here guys I put these in a Google Docs file, hopefully we can get more coming in, I think this thread is a great idea. I'll keep updating it as I finish my build as I have either thrown away or misplaced most of my old bolts.
That's what zip-lock bags are for.... You can even stick a post-it note or scrap of paper inside the zip-lock bag and write on it what the bolts are for. If you are doing a long term project, this is the best way to keep track of the bolts and other small hardware items. Throw all the zip-lock bags in a 5 gallon bucket and it is easy to keep up with all the small parts.
Great thread idea!
If any of you were like me and threw away your old K member before removing the bolts, here's the a arm bolt size.
m16x2.0x117.5. #N808476 S301
They're pretty hard to find...
http://www.palmerbolt.com/catalog.asp?prodid=596691&showprevnext=1
I called up QA1 to see if they had a kit or knew what size they were... they old me to use the old bolts. :shrug: If they are anything like my K member bolts they were half rusted through and two of them snapped completely off when I went to remove them! Speaking of which I will post those bolt sizes as soon as I get my new ones.
