wmburns
SN Certified Technician
Previous responses requested an inspection for vacuum leaks under the hood. How hard was it to spot the bad hose?
Try this. Remove the small vacuum line from the EVAP purge valve and verify there is vacuum on the line with the motor running. If no vacuum, consider that the line may be broken or crushed between the EVAP valve and the Throttle body Tee.
