pin test HX
2003 PCED OBD SECTION 5: Pinpoint Tests
Procedure revision date: 08/19/2002
HX: Evaporative Emission (EVAP) Monitor and System HX: Introduction
HX1 DTC P0443: INSPECT EVAP CANISTER PURGE VALVE CIRCUIT FOR INTERMITTENT FAILURE
Rerun KOEO, KOER Self-Tests and retrieve Continuous Memory DTCs.
Is DTC P0443 present in Continuous Memory Self-Test only?
Yes No
The fault that produced Continuous Memory DTC P0443 can be intermittent. GO to Z1 . If OK REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). GO to HX2 .
HX2 DTC P0443: CHECK VPWR VOLTAGE TO EVAP CANISTER PURGE VALVE
Key off.
Disconnect EVAP canister purge valve.
Key on, engine off.
Measure voltage between VPWR circuit at the EVAP canister purge valve harness connector and battery negative post.
Is voltage greater than 10.5 volts?
Yes No
For LS6/LS8/Thunderbird/2.3L Focus:
KEY OFF. GO to HX3 .
For All others:
KEY OFF. GO to HX4 REPAIR open circuit.
HX3 CHECK EVAP CANISTER PURGE VALVE RESISTANCE FOR LS6/LS8/THUNDERBIRD/2.3L FOCUS
Note: EVAP canister purge valve resistance reading must be taken with engine cooled down.
Measure EVAP canister purge valve resistance.
Is resistance between 2.5 and 6.0 ohms?
Yes No
GO to HX5 . REPLACE damaged EVAP canister purge valve. COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ).
HX4 CHECK EVAP CANISTER PURGE VALVE RESISTANCE
Is resistance between 30 and 38 ohms?
Yes No
HX5 CHECK EVAP CANISTER PURGE VALVE CIRCUIT FOR OPEN IN HARNESS
Note: Refer to the PCM connector pin numbers in the beginning of this pinpoint test.
Disconnect PCM.
Measure resistance of EVAP canister purge valve circuit between PCM harness connector pin and EVAP canister purge valve harness connector.
Is resistance less than 5.0 ohms?
Yes No
GO to HX6 . REPAIR open circuit.
HX6 CHECK EVAP CANISTER PURGE VALVE CIRCUIT FOR SHORT TO PWR GND IN HARNESS
Disconnect scan tool from DLC.
Measure resistance between EVAP canister purge valve circuit at the EVAP canister purge valve harness connector and battery negative post.
Is resistance greater than 10,000 ohms?
Yes No
GO to HX7 . REPAIR short circuit.
HX7 CHECK EVAP CANISTER PURGE VALVE CIRCUIT FOR SHORT TO VPWR IN HARNESS
Key on, engine off.
Measure voltage between EVAP canister purge valve circuit at the EVAP canister purge valve harness connector and battery negative post.
Yes No
REPAIR short circuit. REPLACE PCM. (Refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ).
HX18 DTC P1450: CHECK FOR VISUAL CAUSES OF EXCESSIVE FUEL TANK VACUUM
Note: If the EVAP canister-CV solenoid and fuel tank assemblies are not accessible during this pinpoint test step, GO to Evaporative Emissions, Section 303 in the Workshop Manual for removal instructions. For Aviator application, REFER to Section 310 in the Workshop Manual for removal instructions.
Check for kinks or bends in the fuel vapor hoses/tubes (EVAP canister purge outlet tube and EVAP canister tube).
Visually inspect EVAP canister inlet port, CV solenoid filter and canister vent hose assembly for contamination or debris.
Check CV solenoid filter for blockage or contamination.
Is a fault indicated?
Yes No
REMOVE any contamination or debris around fuel vapor hoses/tubes and EVAP canister- CV solenoid assembly. REMOVE kinks or bends in EVAP canister purge outlet tube, EVAP canister tube and canister vent hose assembly. CLEAR Continuous Memory DTCs. FOLLOW the Vehicle Preparation for Monitor Repair Verification Drive Cycle and COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Drive Cycles ). RETRIEVE Continuous Memory DTCs. If DTC 1450 is still present, GO to HX19 . GO to HX19 .
HX19 CHECK FUEL TANK PRESSURE SENSOR VOLTAGE
Connect scan tool.
Key on, engine off.
Access FTP V PID.
Is the FTP V PID between 2.40 to 2.80 volts with the fuel filler cap on?
Yes No
A possible intermittent condition on the FTP sensor circuit can cause the DTC P1450. GO to Z1 . If circuit is OK, REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310), Diagnostic Trouble Code/Symptom Chart in the Workshop Manual for a blocked (plugged) EVAP system condition. KEY OFF. GO to HX20 .
HX20 CHECK FUEL TANK PRESSURE SENSOR VOLTAGE WITH FUEL FILLER CAP REMOVED
Remove the fuel filler cap.
Key on, engine off.
Access FTP V PID.
Is the FTP V PID between 2.40 to 2.80 volts with fuel filler cap off?
Yes No
REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310), in the Workshop Manual for a blocked (plugged) EVAP system condition. KEY OFF. GO to HX21 .
HX21 CHECK FOR OTHER DTCS PRESENT
Check for other three wire sensor DTCs (KOEO, KOER or Continuous Memory) present with the DTC P1450.
Are other DTCs present?
Yes No
RETURN to Diagnostic Subroutines, Section 4 , for direction in addressing the other DTCs. KEY OFF. GO to HX22 .
HX22 CHECK VREF FROM PCM TO FTP SENSOR
Disconnect FTP sensor.
Key on, engine off.
Measure voltage between VREF and SIG RTN circuits at the FTP sensor harness connector.
Is voltage between 4.0 and 6.0 volts?
Yes No
KEY OFF. REPLACE damaged FTP sensor. CLEAR Continuous Memory DTCs. FOLLOW the Vehicle Preparation for Monitor Repair Verification Drive Cycle and COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ). RETRIEVE Continuous Memory DTCs. If DTC P1450 is still present, REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310), Diagnostic Trouble Code/Symptom Chart, in the Workshop Manual. KEY OFF. GO to HX23 .
HX23 CHECK FOR OPEN VREF AND SIG RTN CIRCUITS BETWEEN PCM AND FTP SENSOR
Disconnect PCM.
Measure resistance of VREF circuit between PCM harness connector pin and FTP sensor harness connector.
Measure resistance of SIG RTN circuit between PCM harness connector pin and FTP sensor harness connector.
Is each resistance less than 5.0 ohms?
Yes No
REPLACE PCM (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR open circuit.
HX26 DTC P0452: CHECK FOR FTP SENSOR CONNECTOR CONTAMINATION
Key off.
Visually check for liquid fuel contamination of the FTP sensor electrical connector.
Check for completely submerged FTP sensor (tank mounted type only) in liquid fuel (can affect correct FTP voltage reading).
Does FTP sensor and its electrical connector show signs of fuel contamination?
Yes No
REPAIR FTP sensor electrical connector as necessary. ADJUST fuel tank overfill. GO to HX27 .
HX27 CHECK FOR LOW FTP SENSOR VOLTAGE
Note: FTP sensor input with no pressure/vacuum on the fuel tank (filler cap open or not open to atmosphere) is between 2.37 and 2.97 volts.
Connect scan tool.
Key on, engine off.
Access FTP V PID.
If FTP V PID is not present on the scan tool, measure voltage between FTP and SIG RTN circuits at the PCM harness connector with PCM connected.
Is measured voltage or FTP V PID reading less than 0.22 volt?
Yes No
KEY OFF. GO to HX28 . The fault that produced the DTC P0452 is intermittent. GO to Z1 .
HX28 CHECK OPPOSITE INDUCED HIGH FTP SIGNAL
Connect a jumper wire between VREF circuit and FTP circuits at the FTP sensor harness connector.
Key on, engine off.
Measure voltage between FTP circuit at the FTP sensor harness connector and chassis ground.
Is measured voltage reading between 4.0 and 6.0 volts?
Yes No
REPLACE FTP sensor. REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310) in the Workshop Manual for component removal and installation. RESTORE vehicle. FOLLOW the Vehicle Preparation for Monitor Repair Verification Drive Cycle and COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ). REMOVE jumper. GO to HX29 .
HX29 CHECK VOLTAGE BETWEEN VREF AND SIG RTN CIRCUITS AT FTP SENSOR
Key on, engine off.
Yes No
KEY OFF. GO to HX30 . VREF voltage is out of range. GO to C1 .
HX30 CHECK FTP CIRCUIT FOR SHORT TO SIG RTN OR PWR GND IN HARNESS
Disconnect PCM.
Measure resistance between FTP and SIG RTN circuits at the PCM harness connector.
Measure resistance between FTP circuit at the PCM harness connector and battery negative post.
Is each resistance greater than 10,000 ohms?
Yes No
REPLACE PCM (REFER to Section 2, Drive Cycles ). REPAIR short circuit.
HX33 DTC P0453: CHECK FOR HIGH FTP SENSOR VOLTAGE
Note: FTP sensor input with no pressure/vacuum on the fuel tank (fuel filler cap open or not open to atmosphere) is 2.37 to 2.97 volts.
Connect scan tool.
Key on, engine off.
Access FTP V PID.
Is measured voltage or FTP V PID reading greater than 4.50 volts?
Yes No
KEY OFF. GO to HX34 . The fault that produced DTC P0453 is intermittent. GO to Z1 .
HX34 CHECK FTP CIRCUIT FOR SHORT TO POWER
Key on, engine off.
Measure voltage between FTP circuit at the FTP sensor harness connector and battery negative post.
Is the voltage greater than 10.5 volts?
Yes No
KEY OFF. The FTP is indicating a short to VPWR. GO to HX35 . KEY OFF. GO to HX36 .
HX35 CHECK FTP CIRCUIT FOR SHORT TO VPWR IN HARNESS
Disconnect PCM.
Key on, engine off.
Measure the voltage between FTP circuit at the PCM harness connector and battery negative post.
Yes No
REPAIR short circuit. REPLACE PCM. (REFER to Section 2 , Flash EEPROM.)
HX36 CHECK OPPOSITE INDUCED LOW FTP SIGNAL
Connect a jumper wire between SIG RTN and FTP circuits at the FTP sensor harness connector.
Key on, engine off.
If a scan tool communication concern exists, turn the key off, remove jumper immediately and GO to HX41 .
Access FTP V PID.
Is measured voltage or FTP V PID reading less than 0.10 volt?
Yes No
REMOVE jumper. GO to HX37 . Unable to induce opposite signal. KEY OFF. GO to HX39 .
HX37 CHECK FOR IN RANGE VOLTAGE BETWEEN VREF AND SIG RTN CIRCUITS AT FTP SENSOR
Key on, engine off.
Measure voltage between VREF and SIG RTN circuits at the FTP sensor vehicle harness connector.
Yes No
KEY OFF. GO to HX38 . VREF voltage is out of range. GO to C1 .
HX38 CHECK FTP CIRCUIT FOR SHORT TO VREF IN SENSOR OR HARNESS
Disconnect PCM.
Measure resistance between FTP and VREF circuits at the PCM harness connector. (For 150 PIN PCM, measure to both VREF pins.)
Is the resistance greater than 10,000 ohms?
Yes No
REPLACE FTP sensor. REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310), in the Workshop Manual for component removal and installation. RESTORE vehicle. FOLLOW the Vehicle Preparation for Monitor Repair Verification Drive Cycle and COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ). REPAIR short circuit.
HX39 CHECK FTP CIRCUIT FOR OPEN IN HARNESS
Disconnect PCM.
Measure resistance of FTP circuit between PCM harness connector pin and FTP sensor harness connector.
Yes No
GO to HX40 . REPAIR open circuit.
HX40 CHECK FOR OPEN SIG RTN CIRCUIT BETWEEN PCM AND FTP SENSOR
Yes No
GO to HX41 . REPAIR open circuit.
HX41 CHECK FTP CIRCUIT FOR SHORT TO VREF IN PCM
PCM disconnected.
Yes No
REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR short circuit.
HX43 DTC P0457: CHECK FOR MISSING OR LEAKING FUEL FILLER CAP
Check for missing fuel filler cap.
Check for a loose fuel filler cap.
Check for possible cross-thread fuel filler cap condition.
Is a concern present with the proper installation of the fuel filler cap?
Yes No
REPLACE cross-threaded or damaged fuel filler cap. RECONNECT and TIGHTEN the fuel filler cap only one-eighth turn so that the cap initially clicks by sound or touch. COMPLETE PCM KAM Reset to clear DTCs and adaptive memory. (REFER to Section 2, Diagnostic Methods ). COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ). RERUN Quick Test. If DTC P0455 is present, REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310), Diagnostic Trouble Code/Symptom Chart in the Workshop Manual. COMPLETE PCM KAM Reset to clear DTCs and adaptive memory. (REFER to Section 2, Diagnostic Methods ). COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ). RERUN Quick Test. If DTC P0455 is present, REFER to Evaporative Emissions, Section 303 (for Aviator, REFER to Section 310), Diagnostic Trouble Code/Symptom Chart in the Workshop Manual. Otherwise, INFORM the vehicle owner that it is important and necessary to immediately install the fuel filler cap after every refueling event.
HX65 DTC P1451 OR P0446: CHECK VPWR VOLTAGE TO CV SOLENOID
Key off.
Disconnect canister vent (CV) solenoid.
Connect a non-powered test lamp between CV and VPWR circuits at the CV solenoid harness connector.
Key on, engine off.
Attempt to close and open CV solenoid driver in PCM by accessing Output Test Mode.
Select ALL OFF mode.
Cycle START button ON and OFF, and observe the test lamp.
Does the test lamp cycle on and off (light up and turn off)?
Yes No
KEY OFF. GO to HX66 . For test lamp always off :
GO to HX67 .
For test lamp always on :
KEY OFF. GO to HX70 .
HX66 CHECK CV SOLENOID RESISTANCE
Measure CV solenoid resistance.
Is resistance between 48 and 65 ohms?
Yes No
Unable to identify fault at this time. GO to Z1 . REPLACE damaged CV solenoid. COMPLETE an EVAP system leak test at the evaporative test port to VERIFY that a leak did not occur during component replacement. FOLLOW the Vehicle Preparation for Monitor Repair Verification Drive Cycle and COMPLETE an Evaporative Emission Leak Check Monitor Repair Verification Drive Cycle (REFER to Section 2, Drive Cycles ).
HX67 CHECK FOR OPEN VPWR CIRCUIT BETWEEN CV SOLENOID AND POWER RELAY
Measure voltage between VPWR circuit at the CV solenoid harness connector and battery negative post.
Yes No
KEY OFF. GO to HX68 . KEY OFF. REPAIR open circuit.
HX68 CHECK VPWR CIRCUIT FOR OPEN IN HARNESS
Disconnect PCM.
Measure resistance of VPWR circuit between PCM harness connector pin (or for 150 PIN PCM, the VPWR fuse to the power relay) and CV solenoid harness connector.
Yes No
GO to HX69 . REPAIR open circuit.
HX69 CHECK CV CIRCUIT FOR OPEN IN HARNESS
Measure resistance of CV circuit between PCM harness connector pin and CV solenoid harness connector.
Yes No
KEY OFF. REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR open circuit.
HX70 CHECK CV CIRCUIT FOR SHORT TO PWR GND IN HARNESS
Disconnect PCM.
Measure resistance between CV circuit at the CV solenoid harness connector and battery negative post.
Yes No
RECONNECT scan tool. GO to HX71 . REPAIR short circuit.
HX71 CHECK CV CIRCUIT FOR SHORT TO PWR OR CHASSIS GND IN HARNESS
Key on, engine off.
Measure voltage between CV circuit at the PCM harness connector and chassis ground.
Is voltage less than 1.0 volt?
Yes No
KEY OFF. REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). KEY OFF. REPAIR short circuit to VPWR, VREF or chassis ground.
HX76 DTC P0460, P0462 OR P0463: CHECK FUEL TANK LEVEL VOLTAGE RANGE
Note: For Focus, Escape, Mustang, LS6/LS8, Thunderbird, Town Car, Windstar, Explorer/Mountaineer, Aviator, 4.6L/5.4L E-Series, F-Series, Expedition/Navigator/Blackwood and Excursion applications, do not continue with step HX76. Instead, go to Instrument Cluster Section 413, fuel level indicator or Rear Electronic Module (REM) diagnosis in the Workshop Manual.
Key on, engine running.
Access fuel level input voltage (FLI) PID.
Is the fuel level input voltage (FLI) PID reading between .25 and 4.5 volts?
Yes No
GO to HX77 . GO to HX80 .
HX77 CHECK FOR FUEL TANK FLOAT LEVEL RESPONSE
Key on, engine off.
Observe the FLI PID.
If fuel level is under one quarter (25% on FLI PID), add fuel (7.57 to 11.36 liters [2 to 3 gallons]) to the fuel tank.
If fuel level is greater than three quarters (75% on FLI PID), drain (7.57 to 11.36 liters [2 to 3 gallons]) fuel from the fuel tank.
Did the FLI PID indicate a movement upward or downward as fuel is either added or drained?
Yes No
No concern found at this time. GO to Z1 for possible intermittent condition. (Frequent filling of the fuel tank without allowing fuel level to drop below the full mark may contribute to a P0460 DTC.) KEY OFF. REFER to Instrument Cluster Section 413 in the Workshop Manual for inoperative fuel level sender.
HX80 CHECK FLI CIRCUIT VOLTAGE AT FP MODULE
Disconnect the instrument cluster connector to the fuel gauge. (Refer to Instrument Cluster Section 413 in the Workshop Manual or Wiring Diagram manual for cluster connector configuration.)
Key on, engine off.
Measure voltage between FLI circuit at the FP module harness connector and battery negative post.
Is voltage greater than 5 volts?
Yes No
KEY OFF. GO to HX81 . KEY OFF. GO to HX82 .
HX81 CHECK FLI CIRCUIT FOR SHORT TO VPWR IN HARNESS
Disconnect PCM.
Key on, engine off.
Yes No
REPAIR short circuit. REPLACE PCM (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ).
HX82 CHECK FLI CIRCUIT FOR SHORT TO PWR GND IN HARNESS
Disconnect PCM.
Measure resistance between FLI circuit at the PCM harness connector and battery negative post.
Yes No
GO to HX83 . REPAIR short circuit.
HX83 CHECK FLI CIRCUIT FOR SHORT TO CASE GND IN HARNESS
Measure resistance between FLI and CASE GND circuits at the PCM harness connector.
Yes No
GO to HX85 . REPAIR short between FLI and CASE GND circuits.
HX85 CHECK FLI CIRCUIT FOR OPEN IN HARNESS
Measure resistance of FLI circuit between PCM harness connector and fuel pump (FP) module (pigtail) harness connector.
Measure resistance of FLI circuit between PCM harness connector and the instrument cluster fuel gauge harness connector.
Is each resistance less than 10.0 ohms?
Yes No
GO to HX86 . REPAIR open circuit.
HX86 CHECK CASE GND CIRCUIT FOR OPEN IN HARNESS
Measure resistance of CASE GND circuit between PCM harness connector and FP module (pigtail) harness connector.
Measure resistance between the CASE GND circuit at the PCM harness connector and the fuel gauge ground at the instrument cluster fuel gauge harness connector.
Yes No
REFER to Instrument Cluster Section 413 in the Workshop Manual (reference: Wiring Diagram manual) for fuel gauge diagnosis. REPLACE fuel gauge or REPAIR as necessary. Then RERUN Quick Test. If DTC P0460, P0462 or P0463 are still present, REPLACE PCM (refer to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). REPAIR open circuit.
HX88 CHECK FUEL CAP LAMP ALWAYS ON W/O DTCS
Disconnect PCM.
Key on, engine off.
Is the Check Fuel Cap Indicator Lamp OFF with the PCM disconnected?
Yes No
KEY OFF. REPLACE PCM (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). The PCM has not attempted to ground the circuit between the Check Fuel Cap Indicator Lamp and corresponding PCM pin. This has not turned the indicator lamp ON. REFER to Instrument Cluster Section 413 in the Workshop Manual.
HX89 CHECK FUEL CAP LAMP ALWAYS OFF W/O DTCS
Key off.
Disconnect the Check Fuel Cap Indicator Lamp harness connector at the instrument cluster.
Disconnect PCM.
Measure resistance between PCM harness connector pin (refer to Fuel Cap Off Indicator Lamp PCM Pin Table at the beginning of this pinpoint test for correct pin number) and Check Fuel Cap circuit at the indicator lamp harness connector.
Yes No
REFER to Instrument Cluster Section 413 in the Workshop Manual to diagnose instrument cluster and Check Fuel Cap Bulb. If OK, REPLACE PCM (REFER to Section 2, Flash Electrically Erasable Programmable Read Only Memory (EEPROM) ). VERIFY repair by turning key to ON position (lamp will turn OFF in 3 seconds). REPAIR open circuit. VERIFY repair by turning key to ON position (lamp will turn OFF in 3 seconds).
