Yikes! Spray paint and side mirrors?
pcm2a
12
My side mirrors on my 1992 are crotchety looking at best. I pulled them off today, taped them up and spray painted them with some flat black color. One of them I accidentally touched and it left a big fingerprint. To fix that I tried to wipe it with a paper towel and oh no is all I can say. That turned a smooth even paint into a giant disaster.
What is the next step? Let the paint dry then try to remove the paint with some paint thinner and try again?
Will putting another coat on top of it in a whlile smooth out the garbage I created? It looks like if you tried to paint it on with a paint brush now.
Any uneven surface will show thru if another coat is applied. I'd wet sand with 400 grit until the finger print is gone and feels smooth - if you can feel unevenness it will show in the paint. And also I would wet sand the whole mirror housings so the paint will bite better.
I used the googone (lol) to clean the paint up till it was mostly smooth. Then I gave it 4 coats of some gloss spray paint from autozone. Attached is the outcome. That is water on there and not giant drops of paint :)
If you are looking for a glass like finish wait a week for the paint to cure then use a Meguirs #2 cleaning wax and rub it out. After you acheive the smoothnes you want use Meguirs liquid gold wax. :nice: I think you will be surprised at the outcome.
This is what I did....
-sanded down the worn out paint
-sprayed plastic primer
-sanded
-sprayed black trim paint
it's not a gloss look but it comes out extremely even and matches the rest of my flat black trim.
I think the flat black looks better in this situation as it matches the rest of the trim. If all your trim is gloss black, then go with gloss mirrors, but i think gloos with flat trim will make it stand out too much
