Which Is Better Lightning 90mm Maf Or C&l 85mm?
stangboy
3,932
473
194
New Orleans, LA
I'm building a Dart based 363 and I'm trying to figure out which MAF would work better. I have a C&L 85mm that I bought used but a friend of mine said he has a Lightning 90mm that he can give to me. Is bigger better or would the C&L work better?
It sounds like you're putting a lot of money into this build, so I don't think I'd skimp on the meter. You should be researching meters like the Pro M 92 or an ABACO 97. Yes, assuming you are using a quality meter that does a good job of measuring the airflow, bigger really is better for MAF meters. You absolutely don't want it to be any sort of a restriction to airflow.
to a point i agree with this... only issue is when you start having resolution issues that cause driveablity issues.
Agreed, that's why I said "a meter that does a good job of measuring airflow". You see a lot more people having issues with junk meters or malfunctioning meters than you do people with meters that are "too big", though.
Yes, I am putting a lot of money into it and I'm coming to the point of getting the last few things for the motor and its starting to nickel-and-dime me to death. My budget it dwindling away quickly and I haven't even ordered my suspension parts yet. So, I'm just trying to find the best quality parts for the least amount of money....not cheap quality parts tho. Like I said I already have the C&L that I bought thinking it was a 90mm because thats how it was advertised on craigslist. Then I measured it and it turned out to be 85mm. But a friend of mine that used to be a Ford mechanic said he has a 90mm Lightning MAF that he'll give to me. So I figured bigger was better, I just wanted to check with you guys to see if there was something I didn't know. I'll be using the Lightning 90mm. Thanks guys!
What system is the 85mm C&L designed for? It may actually flow better than the LMAF 90, since the sensor probe in the Ford unit is pretty invasive to the flow path. That said, of the two, I'd probably still go with the LMAF. Not sure how I feel about the C&L sampling tube gizmo.
