1992 Mustang Gt 347- Ga
redsn95
38
Albany, GA
*****make offer*****
looking to sell my 92 gt project. it has a 347 with nitrous kit. 5 speed. car isnt running yet. lost interest basically. only things needed is battery, cables, belt, exhaust, electric radiator fan mounted, nitrous kit finished and a front end alignment. engine has never been fired and everything is new. peters performance assembled the engine. i know im gonna take a hit on this so im taking offers. no low balling please.
located in albany ga.
easiest way to reach me is text 229-881-1916
heres a part list:
Cast high pro stroker kit
Block was zero decked
Arp head studs
Arp main studs
Main stud girdle
Windage tray
Miloden 7qt oil pan
Comp cam
Cometic mls head gaskets
Rhs aluminum heads
Crane roller rockers
Trick flow pushrods
Arp valve cover studs
Ford racing valve covers
arp bolts throughout engine (every bolt was new)
Trick flow track heat intake
Trick flow nitrous kit
Msd pro billet distributor
Msd 6al
Msd blaster coil
Taylor race wires
Ceramic coated long tubes
75mm throttle body and egr spacer
Pro-m 80mm maf
42lb injectors
Bbk hi flo fuel rails
Bbk adjustable regulator
Aluminum radiator
255 intank pump
polyurethane motor mounts
Qa1 k-member
Qa1 a-arms
Upr coil over
Strange adjustable struts
Steeda bump steer
Upr caster/camber plates
3.73 gears
Tremec t5z
Pro 5.0 shifter
Spec aluminum flywheel 28oz balance
Spec stage 3 clutch
Firewall adjuster
Triple hook quadrant
Autometer phantom 5” tach/shift light
Autometer phantom oil gauge
Autometer phantom water temp gauge
these part are still in the box:
t-rex fuel pump
proform fan
aluminum catch can
3" x-pipe
