GT40 head 61CC chamber 5 angle valve job by Rick 91GT
exploder intake ported lower by me upper is blended from inlet of the throttle body all the way as far as i can reach with a straight die grinder to remove any flash and casting marks
C&L inlet pipe with all the casting marks and flash removed
C&L meter
24lb injectors (coming soon)
Long tubes with all the welding ground smooth at the flange
B303 cam
1.72 roller rockers matched intake and exhaust
QA1 K member
stock control arms with modded bushings and double nuts
QA1 coil overs 14-175 springs
SN95 v6 electric fan
3G alt
battery in hatch
MSD 6AL2
ford racing wires (for now)
MSD cap and rotor
4.10 gears
spool
UPR radius arm uppers
UPR pro lowers
4cyl springs
focus fuel pump
lakewood 50/50's
no radio
no heat
no air ducts
no power steering
26" slicks on pro stars
thats about all of it
C&L meter
B303 cam
QA1 K member
3G alt
battery in hatch
MSD 6AL2
MSD cap and rotor
4.10 gears
spool
UPR pro lowers
4cyl springs
focus fuel pump
lakewood 50/50's
no radio
no heat
no air ducts
no power steering
