Well 99% sure that yellow wire was the VPWR wire to the ECC relay so I attached it to the starter solenoid with a new fuse link and everything works again except the fuel pump will not prime. Tried another fuel pump relay but no dice.. it seems the ecc relay is the same relay so I tried the new one in there and no dice neither. Im getting volts to the inherta switch and fuel pump
