Ok sure guys the part is 5 bucks ordered online but no. 1 it probably won't be here til the weekend or early next week and no. 2 I just like fixing things if in fact they can be fixed just as good as the part you are going to buy and do the same thing. The coil's pigtail connector has one of the tabs inside missing that holds the wire inside of the connector. It holds it snug to prevent it from moving free of the spade terminal of the coil. I was looking over things I have here and I can either put a piece of rubber in there that will slide in with the wire and secure it, or I can put a little bit of silicone in there to secure it. I was just thinking of those 2 things as possible fixes and just wanted to see what cha think.
With the wire pushed in good inside the connector and attached to the coil, it actually doesn't want to move easily but I definitely want to make sure it doesn't at all because I know it has before, hence my problems I'm thinking as the main culprit of most of them. So yeah don't get it twisted as me being cheap lol but I just like to make things work if I can.
Thoughts.
Also, I'm trying to find the damn charcoal canister on the car. All along I was thinking that the actual thing I have in the pass side under hood was the canister but that is the purge valve itself shaped like a small soda can
Thoughts.
