MoWiskey
I have a 68 that I just went and measured. At the front door posts I have 55 inches and at the a pillar its 55 1/2. I did replace my floor with a dynacorn floor that went right in . I have read that these cars weren't always perfect in demesions. I hope someone else here verifys these measurments.
Mike
for some reason i cant open the pics , but i figure you need between the rockers in the front?i measured two cars and they are both the same 54 1/2 between the rockers and just under the dash it is 53 1/2 .if this is not the measurement you need can you full size the pics?
That is correct, for some reason I have 2 measurements 54.9" and 543/8(which I found written on the rocker I took out. I think it is the same at the top and bottom,but mine is twisting some.
Also is that the same on the rear also?
i noticed a light twist in the rockers on the last car i did ,when i installed the torque boxes i was able to take that out by welding the torque box to the fame rail first then clamping the rocker to the box it pulled the twist out . i also noticed they bow out in the middle slightly.
