North East SSoM Members!!!
Ever have one of those small projects turn into an all day nightmare? I went to change the oil on the bike b/c I saw that it had a Fram oil filter on it and the oil in the little window for the oil level seemed really black. I hate fram so I wanted that thing off there regardless of if the oil was just changed or not. Previous owner said it was changed every start of the riding season but this oil and the filter looked like it had been there awhile. I went and picked up some Amsoil Motorcycle synthetic oil and a Mobil 1 filter, put the bike on the stand and took off the lower fairing and found that the drain bolt had been rounded off. My 12mm socket kept spinning on it and a closed end box wrench did the same thing. I went out and bought a set of Irwin channel locks and one of those gator grip sockets. The gator grip socket is a piece of crap I'm taking that back and the channel locks just spun on the bolt as well. I found another 12mm socket that I had in 1/4 drive and used some step down attachments and put it on my 1/2 drive ratchet. I tapped the socket on the bolt first and then put the ratchet on it and slowly started to apply pressure and it finally broke loose and came out. I got a new bolt and finished the oil change. The oil was quite black when I saw it draining out but now it has some nice fresh oil and a good quality filter. Also shifts much better with the amsoil in it. He said he used the Honda factory oil but hard telling. Good thing hondas are tough and I could dump crisco in the thing and it would still run.
also my new helmet came in
yeah Im sure thats what it was. A new one is on there now. Changed the air filter the other day as well, that deff needed to be done. Id say the bike is in the best condition now then what it was in quite awhile. Just needed a little TLC to bring it back some. The chain is new but it was lacking chain lube or wax on it ( it was pretty dry ) I gave it a really good cleaning and re lubed it. Probably is due to be done again now as far as lube. Ive read you want to have a ratio of 4:1 as far as lubing VS cleaning it.
NO way in hell. They had to have some really big bruises the next day.
Took the bike out for a little while then took out the AR. For the first time out it shot pretty good at just over 200 feet. I was able to hit a piece of wood that was about a foot wide. Glad the sights were close.
wouldnt want to shoot that just once lol
Thats good that you did not have to do a ton of adjustment out of the box. I only went for a short ride just to get the chain hot so I could re lube it. Rode a lot since thurs.
