NikwoaC's "Commitment Issues" Engine Build
Nope! No A/C, aluminum heads, and the normal stuff that makes your car lighter means that it probably weighs less than or very close to 3k lbs. My money is on around 310 rwhp. That's where my car was in weight and power when it did 110mph. Aside from giving you something to prove, what's it going to take to get you to dyno the damn thing? I'm more interested in looking at the curve on that overheaded, undercammed, nobody-should-ever-try-this build.
What is it, like $50 for 2-3 pulls? Maybe we can start a pool for you. go start a project on kickstarter, and we can all throw in $10. When we get to something reasonable, you spend $50 or whatever on the dyno and send the rest to the winner.
Alright, it's scheduled for 10AM Saturday. Afterwords I'll be drinking to either celebrate my success, or drown my sorrows. I'll let ya know.
Reactions: 2 users
Well, I was assuming you were only gonna spin it to a safe 6ish. Maybe just wind it up until you get to 300? hahaha I dont know man, Im just guessing. It's like not every other P headed - letter cam motor so it's a tough guess.
A buddy and I were joking that if my HP number starts with a 2, he may have to drive it home, because I might set it on fire. Then I'm gonna buy a Corvette.
Hey hey hey... what's wrong with a corvette?
Curiosity, what is your current timing? Do you have a wideband on the car? With AFR 165s n/a and around 10:1 compression, I found best base timing was around 18*. I don't remember what the stock ramp was, but I think total timing added like 16*. Memory's a little foggy. AFR should be looking for 13.0ish... I'm excited for the results for the first time in years on a build thread :)
If I was any good at gambling or guessing I would have won the $448 million Powerball last night. So I'll just wait for the results. It better be over 300...it'll be in the upper rpms tho. Good luck and don't set it on fire, just get some more cubic inches to match the heads and intake. Then go out and beat up on some vettes. :cool:
Nothing wrong with Corvettes, I love Corvettes. I could have probably had a nice C5 by now with the money I've spent haha. If I were to buy another car that wasn't a fenderless hot rod, it'd be an LS-powered 'Vette.
Yea there is a wideband in the car. AFRs are whatever the stock computer commands at WOT; I've never messed with the fuel tables. I just input my injector values and MAF transfer function, and outside of a little tweaking of the transfer function, rev limit, and startup airflow, I've done very little changes to the stock tune. Woot AFR floats between high 11s and 13ish, depending on conditions. I think I have my timing set around 14 degrees base.
The dyno session is just supposed to be one of those no-tuning 3-pull things, but he said it's OK if I want to goof around a little with the tune in between pulls, just not for like, 30 minutes. Otherwise he charges $150/hour for a full-blown dyno rental (yikes!).
AFR in the 11s is costing a little power, but with a wide-band you don't need the dyno to play with that. And you can tune your timing at a track. Just go let her rip, and have a little fun. Unless you're letting it get back down to the same temp between each run, tuning isn't going to give you clear cut results, anyway.
