Fastest 1/4 mile time(Factory only!)
Pro-Hawk said:
This is where he started me rolling :rlaugh: First off, is he saying EVERY vette didn't run faster than 15's in the 80's? I'm sure the Callaway vette crowd would love to talk with him about that :rolleyes: The the numbers on the GN/GNX seems a bit of a streeettcchh also to me. Sure these cars pull some out rages numbers now days but not without a bit of tunning. Then there was the TA's that was running 14's all day long. Now I got a friend who bought one completely stock that did a 12 second flatt breaking a track record in Ennis I believe for it's class. O and no it wasn't a V8 either ;) Now for my favorite one that most people don't even know about...1981 Yanko Camaro :nice: Yes Don Yanko built one using a 350 with a single turbo :p Theres a ton of 80's cars that did 14's but I don't think people think twice about them since 14's is walking time now days.
Just for kicks heres a SVO I have to watch out for :eek:
http://hometown.aol.com/fourced/
ummm,,,do you mean Don Yenko? I know he made those,,I think he made less then 50 of them.Callaway was not a factory car,,and if you had a friend with a 12 second TA from the 80's,not only would it be a track record,,but it would also be a WORLD record!! Like Stinger said,this part of the thread is dead!!
Well, I imagine the new focus SVT is faster but it's a different 2.3...the Mazda 3 turbo also uses a turbo version of the "new" 2.3...it's pretty damn fast (relatively speaking) as well.
The fastest "magazine" time I've seen for the SVO is 15.0 at 91.0 mph. This is in 1986 btw. I've seen enthusiasts pull lmid 14's out of them bone stock though. (this is all on street tires).
The 1987 SVO that was canned because they didn't want it to outpower the "legendary" 5.0 made 280hp...too bad they never let it go into production.
From Hemmings Daily blog "Rumors apparently swirled of a more powerful 275hp DOHC SVO in 1987, but such an SVO never materialized." It was nothing more than a thought, you're a founding member and don't know that since gas was so cheap then, the V8's were selling 10-1 over the 4 cylinder cars? And the 87 GT got better gas mileage than an 86 SVO. And if someone was buying one to modify in 87, they would have certainly bought a GT or LX 5.0, the LX 5.0's only weighed 100 lbs more than an 86 SVO and was faster and easier to modify.
You guys crack me up,,I just had this conversation in the 5.0 talk room,,theres no problem,,the 86 vette is a slug!! OK,,how fast do you think it is?? Im gonna have to go in the archives now!! WELL,,HOW FAST??// Im 37,I dont have too read it somewhere,,I "lived it",,I was there when it was new.Ive always been a car guy,I know what Im talking about.You 2.3 guys think your spaecial,,you NOT!!! Your in denail!!!
You lived it at ten?
there were 5.0 mustangs in the low 14's bone stock, but we all know most 5.0's are 15s cars. Magazine tests can be all over the place. Some refuse to slip the clutch from more than idle. Others will launch the balls off the thing with no reguard for duribility or repeatablitly. Some apply correction factors which obviously don't account for traction differences. Just look at track times for the all wheel drive cars to prove that. :lol:
I wouldn't be surprised to be called stubborn or whatever, but I'd dare to wager I'd personally be able to pull a 14 second slip from any '87-'93 302c.i., 5 speed, non-vert fox mustang at complete stock specification, even a fully optioned 93 GT. Perhaps it could be done in a vert and/or auto too, but I've never driven either and so won't speculate.
Now, if by "most" you're including '79-'84 5.0s along with all convertibles with autos, then I'd say you might be right.
I'd never claim that stock 5.0 foxes are competitive by today's pony car standards, but it's seriously annoying to read the assertion or perceived implication that they're 15 second cars on a mustang board from a mustang guy. It's just not true.
Bone stock with less than 100 miles on them. my 87 vert ran 15.1 and my 88 Gt ran 14.2 with nothing more than pumped up front tires on those crappy gatorbacks I did Bob Cosby's or whatever it was called tune up - no silencer, short belt, bumped timing, K&N, unbolted the front sway bar, removed all the stuff from the trunk/hatch, Iced the intake, etc. and ran mid 14's on the vert and 13.80's on on the hatch.
Bone stock with less than 100,000 miles as long as it had good compression, I've been always been able to do that or a few tenths better. I've had a dozen or so 5.0's, I wouldn't go near a vert. or AOD if you paid me. In a fox body of course, I amazes me how good the new automatics are, being able to run as fast or faster than the 5 speed GT's. Bone stock before I did anything I've always been able to run between 14.30's and 14.50's.
And it was called the MM&FF 5 min tune up, by Even Smith. I had multiple LX and GT's (I found the LX's had about one or two tenths advantage from weight savings) I would always spend a few months trying to see how fast I could go with a stock car before I would start modifying it. I'd always use a positive stop shifter, (I learned really quick that if you didn't have one, bending the shifter forks and ruining a perfectly good T5 wouldn't take long at all). I would set the timing to 16 degrees, screen taken out of the MAS, removed silencer on the air filter, removed or used a K&N filter, set the TPS voltage set to 5 volts, use any kind of elec. fan to get rid of that clutch fan, 160 degree thermostat or none depending on if you wanted heat or not, (without one you could cool off the motor a lot faster between runs), or you could used a reducer spacer that had a smaller hole in it. I'd use a phenolic intake spacer so when you used ice to cool the intake it wouldn't heat back up immediately, a small water hose to reroute water around the throttle body spacer, no coolent with water wetter (you're not supposed to used coolent on a dragstrip anyway), removed front sway bar, and everything else inside the car like the spare tire and jack, pumped up front tires and usually the stock rear tires but if I ever had to replace the rears and hadn't started using drag radials yet I would put a little bigger tire on the back like a 255/60/15 or 255/50/16 seemed to work good. I would ice the intake for 15 mins before the next run and make sure I didn't get melted water on the bottom intake that would get under the rear tires I'd use a 44 inch short belt that bypassed everything except for the water pump and alternator. And perfected my launch and 250 rpm power shifts. With those things done, I had no problems running 13.50's to 13.70's. I had a hard time getting street races because everyone thought I was hiding nitrous somewhere. Then with 3.73's and 26x10 MT's on stock wheels, I would come very close to running 12's. They would always give me 5-6 tenths. It was amazing how much money you could make back in the day on Fri and Sat nights running against guys with stock looking Mustangs that just didn't put in the time or effort to test and tune their car to see how fast they could go stock. So many people would just buy a 5.0, take it out to the race hangouts without doing anything then accuse me of lying or hiding nitrous. Taking off a second from dead stock wasn't hard at all if you knew what you were doing and took the time to get there.
Ditto!! Made a lot of $$ back in the day. After a few "used" mustangs I eventually bought a brand new 93 gt and spent that night "tuning" it up. Go to the track and run 14.00-14.2 on stock tires. Personal best was 12.00s with slicks and 100hp shot. Completely stock suspension,longblock,intake,fuel system and full weight. Everybody thought I had a built engine or spraying more than 100hp. Early 90s were a blast!
