Water Pump Bolt Broke Off Inside (with Pictures)
ez out is out but i mulitated the hole. i was able to thread the next size into it nicely tho.
I hear sobbing and see tears coming from a 5.0 Mustang lover's wallet. :(
Let us know how that works out for you.
no me and brother figured things outs. i mulitated the hole i know :shrug: i couldnt get the damn ez out but i did end up getting it out eventually. my brother and i ended up threading the hole nicely threw with the next size up bolt (3/8). luckily it fits through the timing cover, it doesnt fit through the water pump but it will take 2 seconds of drilling one of the holes of the pump. im learning as i go :loser:so this is the last time i use easy outs.
the bolt was flush with the block what should i have done instead of "ez outing" it? because those things are crap. should i just drill it out with a center punch and rethread instead of getting hardened steel stuck in it.
i watched the video and that seems like what he did im just trying to be sure. that would be a much better idea then having to drill one hole of my water pump and have to use one oversized bolt haha.
Now (assuming you got the whole bolt out) would be a good time to pick up and install a helicoil.
:doh:
unfortunately i tapped the hole with a regular 3/8 tap because i didnt know at the time how helicoil inserts work. i wont be able to do that now because i didnt tap the hole with the special helicoil tap which allows to me to put in the insert. i assume this wont work is because the thread pattern is different on both sides of the insert? i believe the only route i can go now is to put my one oversized bolt in and make the water pump hole a tad bigger.
please just correct me if im wrong :doh:
It seem that you have shot yourself in the foot, because now a HeliCoil won't work - the thread sizes are wrong for a HeliCoil.
You will need to proceed with the larger bolt and hope that it isn't too big for the water pump...
This is amazing!!!!:pop: The Pro's 2 -vs- The Grimlins 10!
This is like watching those guys ski off a mountain while behind them there is a huge avalanche barreling down on them... yet, they seem to be having fun!
This predicament would be like Horror Movie on Steroids for me!
Hopefully this does not turn into a costly education. Let me offer one last suggestion as it seems my prior posts fell on dead ears. Loctite makes a chemical type of thread former. You put it on the bolt and in the bolt hole, let it set up and it forms a useable thread. Hopefully you didn't hog out the hole so large that the loctite won't work.
http://www.amazon.com/dp/B000WSEUII/?tag=stangnet-20
I would try that over jamming an oversized bolt in.
well apparently the regular tap for a 3/8 bolt and the tap for the 3/8 helicoil must not be far off because somehow i threaded in the insert perfectly then the oiriginal 5/16 bolt torqued down just fine. me and my brother did one last "Hoo-rah" today and now the car is back together running perfectly with no water leak.
i dont see the big deal? worst case scenario the block is made of cast-iron i could of completely welded up the hole and started a fresh hole.
i know i mutilated the hole, im not afraid to say im the definition of a novice mechanic. this is literally my first bolt extraction LOL
im 21 yrs old and just got interested in mechanics like a year ago. this is my second car
im pleased to let you know that my car is now completely back together and there is zero water leak.
There's a couple of things you can do here. One is find a stepped stud in SAE size and thread. Good luck with that one because they seem to be getting harder and harder to find.
The other thing you can do is buy a short length of STAINLESS all-thread and cut the smaller end yourself.
Thread-lok Blue, would a good addition to the threads going into the block with either of these options.
I'll eat a bug if
Neat idea! That's what I like about Stangnet: I can learn new techniques from other people's experience and background. :D
