Hi,
I did the Instrument cluster diagnostic test when it comes to the bulb test I don't the ABS light come on. I do see it when I start the car. I'm beginning to wonder if something IS wrong with my cluster for sure. I had the odometer fade when I pull the lights on and the fuel needle drop a little bet more than it should. I may take it out check for cold solder joints and calibrate it. Is anyone else not seeing the ABS either? Thanks .
