Alternator Nut. Please Help!!!
Hey guys,
Can someone tell me if the nut that holds the alternator pulley on is a special not. That nut fell off this evening causing the pulley to shift and shred my belt. So now my car is stranded.
Can I just go to Lowes/HomeDeport and get any nut or is it a special nut. Also, is there any kind of washer that needs to be used too?
Oh and it is a 3g alt from a Taurus.
Thanks!
They are just a 5/8 course thread nut 15/16 socket to install but there only about half a thick as a regular nut and yes there is a lock wash that need to be put back on to keep it from backing off again. I just put new under drive pulleys on mine tonight
Sent from my iPhone using Tapatalk - now Free
Thanks! so can I just get a nut and lock washer from a hardware store?
Also, in regards to your under drive pulleys, I kept the Taurus pulley on originally but have an underdrive pulley I might swap now that it is off. Does your u/d pulley sit all the way against the alternator? I noticed my Taurus pulley sits off the alternator a little but when I put the u/d pulley on it sits completely on the alternator which I would think would create a lot of friction and heat.
Thanks again!
You can use a 5/8" ID washer as a spacer. It's pretty common for 2G alt pulleys and underdrives to sometimes hit the case. In this situation, a washer as a spacer helps
Get a hardened one no matter the size. Grade one or two can strip too easily. Grade 5 or 8 are much better under the hood. These are all available from most Ace stores or Do It centers.
