Door And Vent Window
iggy
14
i have a 67 fastback,im having trouble adjusting the window and vent window,do you adjust the vent first or the window first. i put new seals in and new window regulators in and greased them up good.they roll up and down pretty good with door open but when door is closed they roll down good but rolling them up they get hard and harder the last couple of inches, if i readjust them then the back part of window buy the handle rubs on the door. iv spent hours trying. one thing i notice the adjusting screws the one for an allen wrench are a little different in length does it matter which one goes where
thank you
__________________
1967 fastback 289 auto
thank you
__________________
the large headed adjuster goes to the top part of the wind wing the small one goes to the bottom of the slide track.the wind wing and the door glass should be adjusted at the same time. you may have the top of the glass in the back to far in and it is dragging the rubber.check the vent window ,it should have an even spacing all the way up with the stainless that the rubber pushes into.
