Got tuned! 308 RWHP / 365 ft lbs on a Mustang Dyno
Went out and played too!
Updated mods list...
1988 Ford Mustang GT
Engine
Stock E7TE Cylinder Heads
E303 Camshaft
Professional Products Powerforce Plus Harmonic Damper #90007
Professional Products Powerforce Spacer for Ford #81007
Edelbrock Victor High Flow Water Pump
60 lb. Injectors
GT40 Tubular Upper Intake
GT40 Lower Intake
SCT BA2400 Calibrated for 60 lb injectors
Anderson Power Pipe for
Vortech
Vortech V1 HO Supercharger Kit
8 rib/6 rib HO Crank Pulley pulley
3.33 8 Rib Supercharger Pulley
MSD 6A Ignition Coil
Black Magic Extreme 3300 CFM Fan
Fluidyne Aluminum 3 core radiator
BBK Shorty Headers
BBK H Pipe
Flow Master Mufflers
Ford Racing 8mm Spark Plug Wires
Professional Products Adjustable Fuel Pressure Regulator
BBK Underdrive Water Pump Pulley
65mm Throttle Body
65mm EGR Spacer
Lentech Street Terminator AOD Transmission
9.5 inch converter = 2600 stall
Hayden Transmission Cooler
Chrome Ford Racing Transmission Pan
Poly Transmission Mount
130 Amp Alternator Swap
Optima Red Top Battery
190 lph Fuel Pump
T-Rex Inline Add a Pump
Suspension
Kenny Brown Double Cross Subframe Connectors Welded
Global West Strut Mounts
Global West Rear
Control Arms
Poly Sway Bar Bushings
5 lug conversion
16 inch Chrome Cobra Replica Wheels
96 Mustang 2 piston caliper polished Front Brakes
04 Cobra Differential
3.27 Gears
31 Spline Axles
Aluminum 1 Piece Ford Racing Drive Shaft
Wilwood Adjustable Brake Proportioning Valve
1993 Cobra Master Cylinder
Stock Brake Booster
BBK Lowering Springs
KYB Rear Shocks
Interior
Corbeau FX1 Pro Racing Seats
Corbeau Dual Locking Race Seat Brackets
New Black Carpet Front & Rear
New Black Seat Belts Front & Rear
New Black Premium Door Panels
New Black Dash Pad
New Black Door Arm Rest Pads
New Black Center Console Arm Rest Lid and Rebuild
New Black Door Skid Plates
New Black Headliner
New Black Sun Visors
Painted All interior Pieces Black if not bought new
Exterior
Black Housing One Piece Headlights
Smoked Black LED Tail Lights
Smoked Fog Lights
Antenna Delete
