Hi all,
So I've read through the forum trying to nail down a solution and haven't gotten anything definitive. I've got a 1968 Mustang, 302 automatic. Two problems I am currently having are: It starts perfectly fine. Often times I don't even have to pump the gas pedal. Runs/idles just fine also but whenever I put it in gear (either drive or reverse) it dies almost immediately. I can put it in park and it fires right back up. Thinking it may either be a vacuum leak or issue with the coil maybe. It does have the original distributor with a Pertronix Ignitor on it. Second issue is that I cannot start the vehicle in neutral. Just started happening the same time as the other issue and was wondering if they are related?? Thanks in advance for any guidance.
