D
Deleted member 87397
Parts Located in Frisco, Tx
I still have a lot of stuff left and tons of original 4 eye stuff that's hard to come by if anyone needs anything. I'm only listing stuff I can ship easily. If you are local and need something bigger, see if I have it. Here's a list of what I have. It's not comprehensive, so if you don't see it listed ask about it. Send me a PM if you are interested in something and we can talk price. If you are on this forum you'll know whether it will fit your year so I'm not listing years.
Front and Rear bumper shocks
Fuel pump bracket
Fuel Level Sending Unit (Working)
A9P ECU
Mass Air Conversion Harness (Computer to MAF sensor 4 wire)
BBK adjustable fuel pressure regulator
BBK liquid filled fuel pressure gauge
MSD Pro Billet Distributor (Super low miles)
MSD Multi Angle plug wires (Super low miles)
MSD Ignition Coil (Super low miles)
Ford Mass Air Flow Sensor
C&L 76 MM MAF housing with 24# calibration tube
Steering wheel with cruise buttons
Turn signal and wiper levers (Originals)
Fog Light Switch
Wiper arms (originals)
Hood hinges
Ford clutch cable (2000 miles only)
UPR 3 position clutch quadrant
UPR Firewall adjuster
Throttle cable and brcket
Vacuum canister with original hardlines
O2 sensor harness (both banks)
Energy Suspension motor mounts (about 3000 miles) Non Vert
Hood release cable
Hood latch
Hood hinges
TAB/TAD Solenoids a.k.a salt n pepper shakers
Fuel pump relay
85 MPH gauge cluster
Complete cruise control system (Funcions perfectly)
Power trunk latch (original)
Trunk latch striker
Trunk Latch actuator
Genuine Ford IAC Valve (low mileage)
FRPP Air adjuster for fine tuning idle
Washer fluid reservoir
Dipstick with tube
Fuel filler neck
E-Brake handle
E-Brake cables
Charcoal Canister with solenoid
Various Interior platics
2 sunvisors in excellent condition, no tears
Metal ashtray housing with tray
Fuel pump bracket
A9P ECU
Fog Light Switch
Hood hinges
Hood release cable
Hood latch
Hood hinges
Fuel pump relay
Trunk latch striker
Dipstick with tube
Fuel filler neck
E-Brake handle
E-Brake cables
