Drivetrain Rear End Comparison
I believe the suspension is original. I can take a picture of the vehicle when I get home from school. To date I know it has subframe connectors and thats it in terms of chassis. As for the other things that you asked I can not confirm at this time.
If it has not been retrofitted with quad shocks, I would consider aftermarket arms and better bushings to minimize wheel hop. Wheel hop was an issue on my 79
that had a SROD and a 302. And that hop is hard on parts.
As far as brake lines fitting, I would check a parts catalog to see if the donor car used the same hose as your 79.
My 79 had ferrous metal drums, not aluminum ones.
I guess I'm not really familiar with the quad shocks that you guys are talking about so I will have to do some homework on that. I think the link that I posted for the control arms does have the sway bar brackets welded to the bottom. Is the difference of using aftermarket control bars and an aftermarket sway bar like night and day difference in terms of handling once they're installed?
Not guaranteed. I have aftermarket control arms and new bushings and shocks and had wheel hop without the quads. Had to put them back on.
Agreed. That is why I typed"minimize". (Quad shocks are a second pair of shocks that are mounted horizontally on the rear axle.) Some on here have lucked out without quad shocks but I am not trying removing mine. If the arms only help some, he is still better off than a stock 79 set up.
I was counting on doing both upper and lower control arms and then a sway bar to get me by. I'm a bit nervous about dropping the ride height any with springs because of header ground clearance issues.
You could get front coil overs and adj the ride height. Ground clearance isn't usually an issue unless it's drastic speed bumps or really steep drive ways. I never had an issue but I ran shorty headers. The h pipe/cat back never has hit anything and I've driven over some speed bumps and had a driveway with some grade to it. Just a fwiw depends on how much you drop it and headers. A 3/4"-1" drop shouldn't ever be a problem
Okay sounds like a plan. Thanks for your input
