No offense, but I suggest you change professions with that kind of advice. There are hundreds if not thousands of guys running 19's and around 300 hp. 24's can easily support 325...
Jrichker posted this several times
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
If you don't know who he is, Decipha is a damn tuning wizard. There are ways to cheat undersized injectors, and people do it every day, but there are a lot of corners that people cut with these cars across the board.
Plus I think Decipha is talking rear wheel and you're talking crank.
