Arguments can be made for everything. Even rebuilding a 5.0 block will require money and additional supporting modifications for it to work 100% correct. I mean even a decent set of aluminum heads for a 5.0 can run anywhere from $1200 to $2500 depending on what you are looking for. Just build what you want and share your progress and knowledge for those to follow in your footsteps.
Goodluck.
I agree 100%. My buddy who owns the shop I grew up around has a '63 SS Nova with a HCI LS1. 425 at the wheels all day, but maaaaan it's not cheap.LSx engines are still expensive to get big numbers out of.
I did quite a bit of research since i was considering buying a first gen cts V. That has the LS6 and LS2 depending on the year.
Look around for one of those engines with the trans. They are NOT cheap.
After a cam they are roughly a 400rwhp hp setup. Add heads and a fast intake and you can get mid 400's but now you are in it a few more thousand bucks.
Putting a GM engine in a fox and getting 500rwhp is No cheaper than do it with a ford engine. So budget should not be the determining factor in a LS swap.
Remember too, just like a ford pushrod engine if you push for big numbers from a small engine, you lose low end.
Tards?
With completely removing the LS engine association from the sloppy mechanics website, Matt has made pages and pages of write-ups, how to diagrams, and videos for building, modding, and tuning megasquirt on anything that runs with gas. He's a very sharp guy who has shared his knowledge with the public so that anyone can figure out the complexities associated with the software.
While I 99% of the time agree with what you say, I'm going to politely disagree with you on that one. While their work IS shoddy at best, the information gleaned from what they do is invaluable.
https://sites.google.com/site/sloppywiki/
If you ignore the LS content and look at the page as a learning tool, I think it is incredible that this information is available for free.
See, the only part of that argument I take issue with his quoting the cost of brand-new aluminum heads. In the build. If you're going to insist on buying brand-new heads for the 302, so should too insist on buying a brand-new LSX engine for the Chevy swap? Otherwise, used aluminum heads can be had for as little $600-$800. Those savings go a long way towards other go fast, or supporting parts.
A lot of the drifters go for the LS1 because it's so compact. It fits in just about anything. The 5.0 with a good intake is hard to fit. I have a facebook friend with a 5.0 in a 240Z drift car.
Ford started ditching the pushrod engine about the same time GM started making any real improvements. There is no reason to improve upon your pushrod engines, when you are going to overhead cam engines.
Kurt
