Hello all. I have been troubleshooting a problem with my mostly stock 93 5.0 for a couple of months now and am highly frustrated. I just cannot find the problem.
Car:
93 For Mustang 5.0 V8 - 170k Miles - Mostly Stock
Original Engine - Block/Heads/Intakes (upper/lower)
Original Exhaust
Original EEC
Primary Problem:
Timing does not advance at idle or while revving up the engine. SPOUT in or out does nothing.
EEC Codes:
KOEO: Code 11 (o,c) - system OK
KOER: Code 18 (r) - SPOUT circuit open
The Check Engine Light is NOT on.
EEC Cylinder Balance Test - 90 - system OK
Aftermarket Engine related mods before the problem showed up:
Upgraded alternator
Additional alternator wire - alternator to battery
Upgraded ground wire - battery to engine
Dual Electric Fans and Fan activation Thermostat
Upgraded water pump
Upgraded Radiator
All of the above upgrades were performed 6 months+ before I noticed the problem. After the problem showed up I started troubleshooting and decided I would go ahead with some planned upgrades and maybe get lucky with resolving the problem at the same time. (I was wrong )
Aftermarket Engine related mods after the problem appeared:
New Idle Air Bypass (IAB)
New Throttle Body
New EGR Plate
New Cold Air Intake
New Throttle Position Sensor (set at .95)
New MSD Coil
New MSD Distributor, including new PIP (timing set at 12 degrees)
New TFI (came with Distributor)
New NKG spark plugs
New MSD spark plug wires
New vacuum hoses
New PCV
Other troubleshooting:
EEC connector pin 36 to ground = infinite resistance
EEC connector pin 36 to TFI pin 2, SPOUT in = less than .6 of resistance
EEC connector pin 4 to TFI pin 5 = 22k resistance
TFI pin 5 to Coil negative = less than .5 of resistance
Unscrewed both EEC grounds, sanded, cleaned, and remounted
I bought new O2 sensors but could not for the life of me get the old ones out even using an O2 wrench so I returned them. I plan on installing a new exhaust next year so I'll replace them then since the EEC showed no codes referencing the O2 sensors.
Secondary problem: (this may be related to the primary problem)
From a cold start, the engine idles fine for about 2 minutes then starts to surge while idling until the engine eventually dies. If I adjust the manual idle screw by about 1/4th of a turn to increase the base idle ~200-300 RPMs then the idle stabilizes.
Any help would be appreciated.
Car:
Original Exhaust
Original EEC
Primary Problem:
EEC Codes:
Upgraded alternator
Upgraded water pump
Upgraded Radiator
New Throttle Body
New EGR Plate
New Cold Air Intake
New MSD Coil
New NKG spark plugs
New vacuum hoses
New PCV
