Frpp M-5500 Rear Upper Control Arms, $200 Bucks?
Quick Update. Went to order the Steeda 555-4094 uppers from Blue Oval and call the guy. He says " Ford discontinued them a long time ago and I don't have any." So why the hell are you listing them on your site then? No answer.
So, guess I will go with a set of stock replacement uppers unless somebody has a good set of the FRPP ones laying around.
Why not box your uppers yourself then install a set of the stiffer rubber bushings?
http://www.maximummotorsports.com/M...Bushings-AxleDifferential-Side-pair-P543.aspx
Guess that is the plan. I dont have a welder so after the cost of the bushings, plate, getting it welded, and driving back and forth, the extra few bucks for them already done was appealing. Burns my chaps those ass clowns still have the part listed on their website. The guy was like " yeah we've been getting a lot of calls on them." Then why not take it off your site as you don't stock it.
On a Panther body (Grand Marquis, Crown Vic), performance website, it states the rear control need to flex to avoid binding and to keep ride quality. I thought it was nuts until I read the long post and related materials. Big sway bars with reasonable springs and shocks are going on my multi use cars.
And as far as control arms on 12-second street cars go, I dropped three tenths off of my quarter mile time when I upgraded the control arms on my '89 with the stock 5.0. Ran 12.91 @ 103 with a 1.69 60-foot time on the stock motor and street tires.
In my opinion a 1.69 on aftermarket suspension in a stock 5.0 is not impressive. I've gone 1.69 in a full weight stock motor all stock/original suspension Fox on street tires. Your accomplishment is impressive, I'm certainly not taking that away, but the proof in the pudding reference to the 60' time does not do it for me.
Out of personal obsession and curiosity, what bolt ons did that stock motor have?
You state you are more confident in the car with poly/solid aftermarket arms and that is great. Confidence will always build speed.
I can tell you that I went from stock rear suspension to solid relocated uppers, solid axle end and poly chassis end (or is it the other way around?) lower control arms and it rides more harsh, is less tolerant to movement, and skitters on bumps in corners much worse than when it did before. There is no way it handles better. I guarantee my car is not the only one that has suffered in the handling department as a result of such parts.
As for tire width, it's not a stead fast rule that wider tires will make a car handle worse. But there is certainly a point where a tire becomes wider enough (thats funny) that the contact patch shape and contact pressure are compromised. In 1992-1993 Pontiac made a Cutlass Calais W41. Hear me out. The road car had a sure footed stance with some nice wide rubber. The SCCA Castrol GTX sponsored race car wore much narrower rubber because it offered more performance. I remember one of the rags interviewing the race team engineer. He went on to explain that the road car tire size was chosen by the marketing department for visual effect. He noted also that the Z28 and Corvette road cars were equally handicapped with their wide rubber. That was straight from a GM engineer making statements about the products his employer put into the public hands.
Sometimes it's hard to admit you are wrong.
Don't forget the removal tool. :D
I'll agree to disagree... on basically everything you said. :D
i find it amazing in the face of solid physical data from well respected resources you continue to dig in...
it will make me question any advice or product you represent
a better course may be to present counter data from your in house engineers otherwise you are sounding questionable at best.
