It's been a stalling point for me.
Originally, the plan was to convert the interior over to 87+ Mustang, and use a tunnel mounted E-brake handle. So in keeping w/ that plan, I threw away the foot actuated e-brake mechanism that came stock on the G Monster.
Now that plan has changed.
I'm starting on the interior endo-skeleton that will be made up of 1.250 thin wall D.O.M. The dash, console(s) arm rests, door pulls will all be one continous bar that completely surrounds the driver, and passenger. The lower console will only have the ball for the shifter sticking through a small slot.
Now the reason for qualifying all of that junk is, that shifter handle, and the center arm rest are all I want visible running down the middle between the two seats. That leaves me w/ two options:
#1. I restore the foot actuated e-brake. That in turn, means more fabrication as I cut the old cable pivot, and anchor points away when I installed my Matrix extreme wanna-be SF connectors.
#2. I do without.
If this was a manual trans car I'd be more motivated to go w/ opt 1, as the instances where the ability to hold the car w/ your hand, while your two feet are working a throttle, and a clutch are warranted.
But it snot.
If it's more a matter of holding the car when parking on a hill to keep it off the park pawl, then there are hydraulic "hill holders" I can more easily adapt for that purpose.
I just have never had an instance where the brakes failed where I actually needed an "emergency brake".
What are the thoughts?
#2. I do without.
But it snot.
