darthcual
My car is also 10mph off as verified by a civic next to me with a digital speedometer. Wonder if I have the same problem?
Blah blah blah, whats it run?
Dunno yet. Gonna take it to a dyno here in the near future.
It will be pretty obvious if have one. 10mph is more then you can correct for with just the little gears.
I forget which tranny your running but I have a 3550. I've never bothered to look at the cable as many times as I've been under her.
I meant at the track, what does it run?
Mine was pretty cracked up on the bottom. I'm running a TKO600 in it.
Dunno yet. Only had it together for a couple of weeks. Been working a lot. I want to get the torque boxes welded up, and replace the LCA's before I track it. That has been on hold cause I have been saving up money to pay off my Cobra.
Dang, man. Haven't seen you in a while. Glad to see you getting it together.
So according to Moser I should be able to grind the ends of the axles a bit to make room for the cross pin. We'll see if I can make them fit.
Go lightly and keep it cool. Get a bucket of water and dip it every 30 seconds or so. That'll keep the temper in your metal. If it starts turning blue, that's bad.
Do you have a saw of some sort that could tackle the job? Grinder = lots of heat.
I had to do the same with my 10 Factory (motive) axles. Apparently it's fairly common. I used a flat file, iirc, it took about 15 minutes per axle.
Joe
