Progress Thread Down For A Decade - Got The Job!
So I don't get it.
If the wiper motor is spaced even farther out, how does doing that keep it out of the engine bay?
And if it's to be relocated, it has to be under the existing sheetmetal that makes up the cowl.
Seems to me if you're putting a hole under the wiper mechanism through the floor of the cowl box,..you're asking for a leak when it rains or it gets washed.
Sounds like show car trailer queen stuff to me.
If I hated my little wiper motor so bad that I had to go through that much to try and hide it,...I'd do away with the mechanism ala race car, seal up the offending holes permanently, spray the glass with rain x, and never take the car out if it looked like it might rain, or hide under an overpass until it passes if it did.
*Edit.....
Dammit! I can see that in the pics it looks like the wiper motor is actually sitting inside the cowl, on the back side of the existing wiper mount point..so no hole in the bottom of the cowl...
Dammit! All of that know-it-all snarkiness on my part condemning this mod, and it looks like there is a way to hide that thing and still have a wiper motor after all...
Dammit!
I'll just go an sit in the corner now...
Whoa, thats a first.
You could make a sheet metal cover for it, also. Not as pretty as hiding it, but at least cover it up if it bothers you seeing it.
Edit* You could also paint it blue, slap a little NOS sticker on it, and play games with noobs that see it. ;)
Reactions: 1 users
@Fordfreak93
I see you have all the holes on your driver side shock tower sanded down to the metal to fill them in. Two of the holes on this tower is for mounting the brake proportion valve if you plan on still running it. I accidentally filled them in and had to drill them back out when I smoothed my bay. Ultimately I ended up removing my stock style proportion valve for a MM delete kit.
b2xmc0vzpcwjsif5djecilxwjzwt2z0xwyd1b-gpkmnzykrrdpf8wauwyzu-gqsionhtng-w1687-h1265-no-jpg.592569.jpg
Uh oh......you're slipping into a Terry rebuild. I forgot whom he visits mostly now, Corrall maybe? I'll watch what you're doing though, next spring I'll tackle my blue car's body. I have lots of dirty plans for it! Lol.
No wiper motor in the eb....damn you....one more thing:D
So I don't get it.
*Edit.....
Dammit!
I know, I know, I'm getting a little out of control over here, but it won't take much to take this car to another level without it being a trailer queen. Having functioning wipers with a hidden motor seems pretty cool to me. All I see at shows are those stupid bullet covers on wiper arms that aren't used anymore. If I decide that I don't really need wipers I can unbolt my hidden motor and slap on a set of bullet covers myself. I'm trying to do this mod without spending a ton of time on it, so far I only have a few hours of scouring the internet and holding parts in the cowl. I'll keep you posted!
@Fordfreak93
Thanks for the heads up! I am still figuring out my brake setup and will be mocking stuff up when the bay is in primer. I was going to run drums in the rear but now I have a complete disc setup so I'll need a proportioning valve. I'll check out the MM kit and I'll also be installing a line lock kit. I have to figure out how to hide and mount everything. Thanks for looking out for me, I hate doing stuff twice!
Page 23 of that thread has more pics of the bracket/mounting, and several pages thereafter with wider shots of the engine bay show the three bolts that attach it to the cowl.
This thread-https://www.stangnet.com/mustang-forums/threads/started-the-84-t-top-coupe.772468/page-8 post 143 @TurboFox shows the bracket he made to move his wiper motor inside the cowl
I posted the pics from that thread on the last page. It's the only inspiration I have, lol. I think I have it down, I might hide the bolts too, no turning back. I'll post up pics if it works :rlaugh:
Reactions: 1 users
So I found a set of wheels this weekend :D Steeda Ultra Lite I 17x9. There are 5 of them new in the box!!! I already have three of these wheels in chrome that were damaged by Tire Kingdom and replaced under warranty and I've been searching all over the country to find one more. These popped up only a couple minutes from my Dad in FL and I had to buy all of them. He scooped them up for me yesterday and they are headed my way! I am thinking about polishing or painting them, but they are so pretty that I'll probably just run them as is for awhile. I may have two of the chrome wheels widened for drag radials or keep extras just in case.
I'm still doing a bunch of welding and grinding, nothing really picture worthy. I should have my wiper motor hidden by this weekend though, stay tuned...
LvcpB6nMim2hj64FvEzUeGPpptpgQNMI-hK6A7_psBF2TNLaenB1sgGeqtV9Gx9Or2p2uQ1-oJNbbFKqgY=w949-h1265-no.jpg
1vofy9d5gAuDfr0KPJmjw7O91oC2H2IhL3ZGhlZKLIL2tWNNdfhUTAWu15yrqx9XRbNVnepQtbPec_cMcw=w949-h1265-no.jpg
0xTEzUu6_YV76fqP2b2YwPPSr7E2JJMn645D8dgKJQ4_EN1yCi5OFFzPM9cuQULhfYY5G2y2xZCw8ezOZ4=w1024-h768-no.jpg
Reactions: 5 users
Thanks! Much needed sound dampener, Fat Mat, way cheaper than Dynamat!
The only thing I worry about with stick on mats is the PITA for paintless dent removal for small dings. Hail and door dings happen.
I do not see any blood in the starting pictures. Anyone who would slam the shifter into another gear while a passenger, risking damage to me and the car, would be living dangerously. Then to slam the door into a mailbox reeks of disrespect, meanness and stupidity. Regardless of the passenger’s gender or relationship, she was lucky you were not the type to run her over in anger.
I wish you easy progress in your rebuild!
First attempt at hiding the wiper motor went well. I have a few adjustments to make, the motor needs to be raised up a little to allow the arm to clear the cowl. I'm thinking this will actually work! I'm going to remake the plate that attaches to the motor itself and raise it up this time. Then I have to straighten the linkage and the wiper arms and I'll have a stealthy wiper system! I also trimmed up the pinch weld and have been grinding welds like crazy! Spending all this time in the bay better be worth it!
I6rB_yu7qVhW54v_VrOoZlYee4CX6qOoMyKQNOI0od7sIG2eqvmSj61h52s9K-go1oO9Iljjl5fMOF8luw=w949-h1265-no.jpg
Qq4iGDowQjxwqtoHdcxM8VW9usldRw-i9tuxPfHZv0Co4RgzR6Zfcr_61K7_nH4FA47RMz-OwgcV3bmKw=w1687-h1265-no.jpg
S70ZyL63rI-QGKQ-KY3C5x5ka36WqdPbh-__1XDwGQltT6HcJ9cfCxZnyvmXM4RS7CwJBP13KHJfNOjTg=w1687-h1265-no.jpg
CS-ybLiJahNih8-YzI74eO7gbd0hg24OUy-BQb8evI9PwHWQ9OfDJywgzd2eyfSWaFCIc-c0dngWr46K0Q=w949-h1265-no.jpg
Reactions: 4 users
What's the wiper motor look like from the front in the engine bay?
I wouldn't mind hiding mine. I don't even use wipers anymore, but need to keep it in place for inspection reasons.
This is what it looks like from the front right now. I'm going to weld the bolts to the firewall and then grind the heads down. The area is concave and the only bolt that really needs to be ground is the bottom one. Then I will cover the concave area with a piece of sheet metal so the whole upper fire wall is nice and smooth. The wiper motor assembly can still be removed and replaced if there are any issues. Even just hiding the wiper motor and being able to see the plate and bolts is better than having that ugly thing hang in the bay, IMO. The way that Trbofox did it, he made the firewall flat but you could still see the three bolt heads. There are lots of options, just depends on how crazy you want to get!
aJjYBu95fMMmMXctX5v_HyyfsJxXRJ5VGP_3hXa6-LzHLNSQBTMZ6Swj9dXm4w0lwSXR_CG78xkYBzsSA=w1687-h1265-no.jpg
Man those wheels look great! I wouldnt mess with the paint being they are so nice, but they are your wheels after all. Great work on the wiper motor. Your progress is motivating.
I finally got them in my hands and you're right, they are way too nice to mess with! I am going to run them as is until they need to be refinished. I would like them to have a slightly darker or "smoked" look, so I might plastidip them. That could help protect them too.
s21b-YBrT_TllzwlEU_JjVHGqkg8jo2dYWx5RYlEE0I_BgKVC6lZRZPFHF7TNO73HaDbsXnJc-YJxw_B0FcQVGYoh0GNE4XQr-nJAaIPM66tjN0GRDkL0eVUQwXd1q30U_cVTwaDrrtsFqJoncsY0P9DKwpQoIf2TUpzEUjOoi0PkKrXG_yPRRN0R2t7B6LWfQTePa1cbT4qSNP4bOqCxvEfaCWQsHqMe1czBolYkuVHXoU38Ce_c4TZfpiJ5tPreESsR7vxjU96CP3wqB0wrzgOXEAH01zCHjLOsB9GqZOI22F--lp-FOwGAsoBeC0w4Tzw7uooGLs3u1DjIZDu6gINTBto1NYQUCwPa20QNeExmRawCAE6kt3HQ0bQl0uOPSQbLuYwz2_eIF-68vsw1vBFWPR8bhYLMD9A7LOvuSpw273u5z2wydFV5uRncVDtEtXT4sqyJ0ySuXD-nuHIiGdlrRJBcxrpsPXaKyjHOA3rLOuBk9Uh5ErLgEIaPIlPkgHTGUIz4xZYZfFN_m5b-W46f9stEn1b_qA21zclovBJ6_4WfAleX5oZtiSIggj2ajFZy4zdAgkC2KAMvK00PL9OkYcoV-4RnISaV6FkSA=w1687-h1265-no
