New MSPNP2 user!
justangs
21
Upstate NY
Hi guys new to the forum and tuning. I have a mostly stock 95 with a mspnp2. Car runs ok but its definitely down on power. Just wondering if anyone could look at my logs and let me know what you think. Thanks
  • 2019-05-24_19.19.01.msq driveable.msq
  • 2019-05-24_18.55.34.msl
I do not see a WB signal coming into the MS, the AFR shows pegged lean the entire time, are you running a wideband? If so did you wire it into the ECU?
Thats the first thing we need to figure out.
I don't have a wide and yet. I wasn't sure it would be necessary being the car is mostly stock. I have planned upgrades so this was the first step in preparation.
ok it is very necessary to make things easy on you..
i suggest the spartan2 from 14point7.com
I agree with the need of the wideband. It is quite a bit harder to tune when you do not have the ability to see what the AFR is. This will one of the main readings you will be using to dial in the tables.
Here is my latest tune and datalog. first the car has left the yard in a while. Thank you for all your help.
  • 2019-06-26_17.30.36.msq lean part throttle.msq
  • 2019-06-26_17.14.34.msl
