Code scanner problem
Change the battery in the scanner and try it again. My guess is the fault lies in the code reader, and not the vehicle as there is no electrical signal from the car that would command it to shut off. The scanner is doing it on it's own.
  • Agree
Reactions: 1 users
The scanner will turn off after 1min if sitting idle. If you turn it on, and let it sit, does it turn off after 10 sec or 1min?
You plug it into the car, turn key to on, and press test and what happens?
