Help With Ignition Problem
93CalypsoConvert
267
80
38
Virginia
Hello,
I'd like to begin with saying this is my first post, so let me know if I'm doing something wrong here. The other day I bought a 1993 Calypso Green convertible and its got some problems I can't quite put my finger on yet. The car was originally a 2.3 5 speed, but the previous owner swapped in a carbureted 5.0. One of the problems is he ditched almost all of the electronics, making the wiring a total nightmare (harnesses and connectors EVERYWHERE). The problem I am having now is no spark while cranking. The second I let off the key, it gets spark and starts. How do I fix this? Where do I need to give to coil power from to get spark while cranking? Also I am trying to reconnect the original tachometer. Do I connect the gauge cluster wire to the negative coil?
Thanks.
Hello, welcome to the forum. There are lots of guys here that can help with this. Pictures are always a huge plus with stuff like this.
You'll need a test light to find the wire on the ignition switch that has power when in the cranking position and in run....but off when switched off. The coil should be connected to that wire. I could be wrong but I think the dark green and yellow stripe wire ( could be tan / yellow ) is coil ground for the tach. Red and light green stripe should be power from ignition switch to coil. ( can be verified with test light ). The ground could be connected straight to a good ground. The computer used the tach ground to control timing. Your car should have a vacuum advance distributor or one of the HEI style that has the coil on top of the cap. These styles mechanically control timing so a straight ground wire can be used for coil.
The 4 cylinder cluster tach won't work right with a v8. It'll read wrong because its set up for a 4 cylinder. Your year ( 93 ) used a signal from the computer to run the tach. The easiest way is to buy a V8 tach and wire the coil negative to it.
The correct way to fix your issue would be to get a complete engine harness for a 93 v8....that would also mean getting a proper computer and going efi. ( bunches of sensors and such ). I wouldn't be mad if you didn't go that route. A carbureted car can be cool if its done clean and with the correct parts.
Carb swaps used to give me a stomach ache but I've noticed we are getting more requests for help in this area and we are here to help.
Most times it's a 4 cyl to V8 swap that get the carb treatment like yours did, in order to help there is a need for some info:
Is the computer still present along with the 4 cyl instruments
Did it run when you acquired it
Do you want to keep the carb or update to efi
Also what is your level of mechanical ability
Make sure the coil/ignition is not connected to the starter solenoid. Letting off the start key, then immediately getting power to the item needed for spark sounds highly suspect of this being the issue.
Yes, the computer is still present. All of the instrument panel works.
It did run when I bought it.
I would like to keep the carb setup.
High mechanical ability.
Ok, thanks for the info. I found the dark green wire you were talking about. Only problem is when I turn the key to crank, the wire either turns off or is grounding somewhere. Still trying to figure out whats going on here.
Found the problem! So the +12 wire that was supposed to run off the ignition switch was actually being run off a wire from the fuse box. It was running off of the ac and blower motor fuse, which deactivates while cranking. I have now routed it correctly and it starts normal. Thanks for the insight.
Reactions: 2 users
