I swapped an 09 4.6 with manual trans into an 05 that was a 4.0 with an auto. I swapped body and engine/trans harnesses and it will not crank. Has anybody had this issue after doing the swap?
Yes I did, I swapped everything from the donor car except for the dash harness, I had to re pin c210 for a pats code. I am not getting communication from the pcm to pin 86 on the starter relay
