88_turbo_9.5
Anyone know where I have to run the wires for my DD dash for fuel level on a ms2pnp for a foxbody? Just acquired one and didn’t get the instructions for that part.
Welcome to Stangnet!Anyone know where I have to run the wires for my DD dash for fuel level on a ms2pnp for a foxbody? Just acquired one and didn’t get the instructions for that part.
Yes you are correctSo then just to be sure I would run the resistor in line between 19/23 pins then y’d to one wire tho the oe gauge cluster harness
The PIMPXS is an MS3 based platform, so the TunerStudio setup would be different. The wiring would be the same except you will be wiring to the open ADC inputs on the stock 60-pin connector.Would these instructions apply to a Pimpxs?
Yes, you are correct for the PIMP systemSo for the Pimp i would jumper with the resistor like shown with the blue wire to pin 50 and 26 instead of 19/23, then set up in TS as shown?
What are you wanting to know specifically? technically we are on the V3 release now. If you are looking for an update on the Pro series line we are currently in the testing phaseAny ETA on when V3 dash will be available by chance?
Is the pro the series with the canbus option to leverage existing factory sensors? If so, that's the one I'm wondering about.What are you wanting to know specifically? technically we are on the V3 release now. If you are looking for an update on the Pro series line we are currently in the testing phase
The DD-EFI Pro Version is going to come with more than one option. The initial release will have an internal I/O for expanding the capabilities of the Megasquirt ECU.Is the pro the series with the canbus option to leverage existing factory sensors? If so, that's the one I'm wondering about.
There will be an expansion connector that will be for wiring to the available 14 inputs digital/analog of which one is already dedicated to fuel level with the necessary resistor for a one wire setup to your factory wiring. The indicators (L/R turn signals, high beam, etc.) will be able to be wired as a digital inputs.So with the V3 it would connect with canbus but how does the factory wiring for fuel level, high beam etc connect to the DD EFI? ..or is that not finalized yet?
We have many options, you will just need to supply us with some dimensions and photos of the location it needs to be installed.OK, tying this into my questions here, is this something that could be configured to run in my 67 (recognizing that the physical layout will need to be different). I was planning to do a Dakota Digital dash for my car, but if I can put something together that ties the MS to a digital dash, that seems like it would be the best of both worlds. I had planned to install a tablet in my console for media and GPS anyway, so that could be an alternate mounting location if it can't be made to fit the 67 dash location.
You have all the options above mounting it as a factory dash replacement or in an alternative location. Using a Digital Dash will provide you access to all the readings the MS sees, while also being able to tune through it if desired as well. You have options of screen sizes and universal mounting or custom bezel, so it just depends on what you would like for your project.OK, tying this into my questions here, is this something that could be configured to run in my 67 (recognizing that the physical layout will need to be different). I was planning to do a Dakota Digital dash for my car, but if I can put something together that ties the MS to a digital dash, that seems like it would be the best of both worlds. I had planned to install a tablet in my console for media and GPS anyway, so that could be an alternate mounting location if it can't be made to fit the 67 dash location.
