2005 GT blown motor
horse sence
6,525
233
Wile Coyote's stunt double
Just picked up a 2005 GT ,the motor is blown . I have a wrecked low mile 2007 GT that i want to pull the motor and drop into the 2005 . My question is ,can i pull the motor and automatic as a unit or am i going to have to split them to get it all out . Motor is the 3 valve and 5 speed auto .
I spent yesterday and today pulling motors ,the 4.6 3 v from the wrecked 07,and the 3 v from the red 2005 ,easiest motors i have ever pulled . And by the way the blown motor in the 05 isnt ! Yep the starter was stuck ,the solonoid kicks but the starter doesnt spin ,i put a breaker bar on the crank and it spins with no problem haha ! Pulled it any way because it had around 170,000 miles on it and the wrecked 07 only has 70,000. Time to pressure wash the engine compartment and the 07 motor and put it back together . And all the shelby trimming is coming off
Reactions: 2 users
It runs ,but i noticed a problem ,the 05 harnes has one plug in different from the motors 07 harness so it looks like i have to change the engine harness . The cluster reads limp mode ,i will hook up my code reader and if i cant find the problem i will stuff a viagra down the throttle body ,that should get it out of limp mode!?!?
If it has a blue oval, it probably does not need a blue pill.
The problem is likely the mismatched harness plugs. Are the plugs for the same things? Can they be adapted to mate?
I went ahead and swapped the harness ,now i have a plug by the oil pan and the new 07 motor doesnt have the plug in like the 05 has . Is this a low oil warning sender and can i simply jump it ,i sure as hell dont want to have to change oil pans
Drill a hole, add an o-ring, and install a level sensor if you've got a mind to have it working.
