03 mustang brake troubleshooting
Oct 2, 2018
Colorado
So dumb people that weren’t me failed to maintain their car and ended up running all the way through their rear passenger brake pads and it spit out the inside pad at somebody point in time. It ended up spitting the piston out the caliper too so that’s fun. It’s then driven for an indeterminate amount of time after and then handed off to me.
I Replaced said caliper and can’t get fluid to come down the line. Front brakes are bled and work (sorta). Peddle sometimes has pressure at 75% down, other times it dumps straight to the floor. If I bleed the fronts it’ll draw fluid out of them resivoir, but not if I bleed from the backs.
My guess is that air got into the ABS modual or even further upstream. Anyone else know or have similar problems?
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,811
499
164
Houston Texas
FYI, if the master cylinder reservoir has been run dry it's necessary to bleed the master cylinder as well. It can be difficult to bleed the master cylinder on the car.
Neuron
Mustang Master
Nov 6, 2016
787
169
83
70
I remember something about different years(with ABS)could be bled normally but newer ones needed a controller for the ABS Pump to get all the air out. I think it was OK up to '98. When I get a chance I will try to nail it down.
Thread starter Similar threads Forum Replies Date
L Clutch brake pedal problems 1965 Mustang Classic Mustang Specific Tech 3
S 66 Mustang front brakes drum to disc conversion 1965 - 1973 Classic Mustangs -General/Talk- 1
Red50Fox 88 Mustang GT 5 lug / disc conversion (almost done!) parking brake question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
J Help with DIY Sequential Brake Lights 67 Mustang Classic Mustang Specific Tech 0
F Electrical 2003 Mustang GT - Brake and Blink Fuses Blow SN95 4.6L Mustang Tech 7
R 1966 Mustang Brake Issues 1965 - 1973 Classic Mustangs -General/Talk- 9
gwirex 1999 mustang Gt brake upgrade 13 inch 1996 - 2004 SN95 Mustang -General/Talk- 3
AUBURN1111 Brakes Cadillac ATS calipers installed! Fox 5.0 Mustang Tech 20
T 91 mustang front brakes lock up Fox 5.0 Mustang Tech 4
S Reoccurring squeak/chirping noise coming from rear. SN95 4.6L Mustang Tech 1
C No brakes 1996 - 2004 SN95 Mustang -General/Talk- 5
Mustang5L5 Caddilac XTS 14" Brembo brakes on a Mustang...under $300 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
G 1967 Mustang Brake Light Problem 1965 - 1973 Classic Mustangs -General/Talk- 8
D Handbrake barely holds 1996 - 2004 SN95 Mustang -General/Talk- 10
D Big brake kit on the cheap? 1996 - 2004 SN95 Mustang -General/Talk- 3
N 347 Mustang RHD Australian. Im new just sayin Gday The Welcome Wagon 3
8 Brakes 88 mustang brakes?? Fox 5.0 Mustang Tech 6
Cool Beans For Sale 1968 Mustang Power Disk Brakes Wheels/Tires/Brakes 0
J 1999 Mustang GT, E-Brake Assembly/Wiring Failure (Help Needed) 1996 - 2004 SN95 Mustang -General/Talk- 1
E 1997 mustang brake lines 1996 - 2004 SN95 Mustang -General/Talk- 1
S Clip/bumper between brake pedal and sensor - what's the part number? mustang gt 2015 2015+ (S550) Mustang -General/Talk 6
Schnelly What are the best brakes for a 2008 GT? 2005 - 2014 S-197 Mustang -General/Talk- 8
B Mustang Brake Master Pipe size Other Auto Tech 7
M 91 mustang rear brake parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
R Disc Brakes for 1968 Mustang 1965 - 1973 Classic Mustangs -General/Talk- 0
G 65 Mustang front disc brake swap. Pulsating 1965 - 1973 Classic Mustangs -General/Talk- 2
K 2014 Mustang GT/CS - 316mm vs 336mm Front Rotor Replacement? 2010 - 2014 Specific Tech 0
Misneachail 2007 Ford Mustang v6 convertible problems extedning from brake light switch replacement 2005 - 2009 Specific Tech 0
Sabretooth Brakes 5-Lug Converted Brakes / Parts - ID Help! Fox 5.0 Mustang Tech 44
S The Dreaded,No Brake Light,Hazard or Turn Signal for 94-04 Mustang. SN95 V6 Mustang Tech 0
ebowie 1995 mustang gt brake upgrade to cobra brakes 1994 - 1995 Specific Tech 5
D 1966 Mustang 2bbl, 289, C4 disk brake conversion Classic Mustang Specific Tech 3
S Best City/Street Brakes (Rotors+BrakePads) for 01 Mustang GT? 1996 - 2004 SN95 Mustang -General/Talk- 2
MoDriver For Sale 64-66 Mustang NOS Parking Brake Lever Return Spring w/extra hardwar Wheels/Tires/Brakes 0
R 95 Mustang GT ABS brake problem 1994 - 1995 Specific Tech 10
MoDriver For Sale 1997-2004 Ford Mustang Front Right Passenger side ABS sensor F7ZC-2C204-AA Wheels Tires Brakes 0
9 Exhaust 92 5.0 gt mustang- emissions/brakes/vaccume leaks/exhaust/CEL Fox 5.0 Mustang Tech 8
P 2015 Ford Mustang Convertible Third Brake light issue (light works, no power) 2015+ Specific Tech 1
S 1998 Mustang GT Hazard Lights and Turn Signals Mixed Up 1996 - 2004 SN95 Mustang -General/Talk- 4
denny j sayers 2011 5.0 mustang manual brembo brake package ! 2010 - 2014 Specific Tech 3
B 2005 Mustang Creaky Brakes - Resolved 2005 - 2009 Specific Tech 3
MoDriver SOLD Real Leather Emergency Brake Boot For A Sn95 Mustang, Black With Black Stitching Interior Exterior Parts 0
MoDriver For Sale J & M Mustang Brake Hose Kit 87-98 Ford Mustang Rear Stainless Steel Wheels Tires Brakes 0
F Story Of The 1969 Mustang And Scarebird Brakes... 1965 - 1973 Classic Mustangs -General/Talk- 3
MoDriver SOLD New Hawk Performance Hps Front Disc Brake Pads Hb194f-665 Mustang (see Description) Wheels Tires Brakes 0
MoDriver SOLD Used 94-04 Mustang Cobra Rear Brake Calipers w/ Carrier Mounts Wheels Tires Brakes 5
D Brakes 85 To 86 Mustang Gt Brake Upgrade Fox 5.0 Mustang Tech 4
B Need Help !!! 2004 Gt No Brake Lights 1996 - 2004 SN95 Mustang -General/Talk- 11
Ceazer 67 Mustang Master Brake Cylinder Drum To Disk Help 1965 - 1973 Classic Mustangs -General/Talk- 6
B 02 Mustang No Brake Lites 1996 - 2004 SN95 Mustang -General/Talk- 2
