I got my speed bleeder hooked up, and watched clear brake fluid pump through the line that went into the reservoir. I choked down inevitability, and removed the transmission.
It fought me every inch of the way.
The plate I made to keep the transmission from falling off the jack worked as intended. Right up until the part where I had to get the thing out from under the car.
It was there that it fell off.
I didn’t expect that i’d have to remove the trans out from under the car, as I expected that i would be able to just push the thing on the jack back far enough, but as low as the car was…that wasn’t happening. Now i’m in-between the proverbial rock and a hard place. The car needs to go up higher, but the trans is now on the jack. I try to move the trans as far to one side as i could, and no sooner did i start pushin, and pullin, off that bitch comes and clanks down on the floor.
And promptly starts puking 75-90 gear oil out both ends.
I drag the thing out from under the car bitchin up a storm, because it’s….75-90 gear oil that is now all over the place. i destroy about 4 microfiber towels cleaning that up, and slide back under the car, hopin to find the smokin gun that is preventing this thing from going into gear..
The needle pilot bearing is where it’s supposed to be, nothing looks bent or fcked up…Except this:
You can see an inconsistent contact pattern on the pressure plate diaphragm. several of the teeth are showing very little contact, while others are showing a much heavier impression. Also, not having ever pulled apart the one other manual transmission i’ve ever had after installing it,I don’t know where the thing is supposed to make contact with these diaphragm fingers…mine is obviously making contact in about 1/4” from the ends.
The sleeve that rides on the t/o bearing looks just like this too,…3/4’s of it exhibiting signs of contact, 1/4 of it no contact at all.
When you measure the pressure plate fingers 180 degrees apart from each other they are between .030, and .040 difference,..from what i understand, this is acceptable. I’ve been talking between the adapter maker, and Spec..the adapter guy is telling me to throw away the cap, and just let the T/O bearing make contact where it normally would..
( when you think about it..it should work better) it’ll contact the diaphragm fingers 1/4” higher, at the ends, which should increase the amount of release that the T/O bearing is capable of generating.
