Can you feel it?
The water starting to trickle past the flood gate?
I said it was gonna happen.
Thursday afternoon it started.
Thursday afternoon I got the Cobra brake brackets to stand off the calipers further that the GT pieces I had.
I removed the cover,and the little bolt that held the pin, then removed the axles and converted the brackets over to the new Cobra pieces. Once everything was converted over, I tried to put the caliper brackets back on.
While the stand off was correct now, there was still about a 1/4" gap between the bracket, and where the caliper mounting surface was.
WTF?
I go get back on the computer and after doing some clicking, discover that there are two different Cobra housing brackets, and obviously,.....I have the wrong ones.
The difference is obvious. I still have a .250"shortfall from being able to bolt the thing together.
So I grubbed around, and found some spacers.
They were too wide. about .100" too wide.
So,...I did what anybody else would do.......I hand filed .100" off of four spacers. I got it close enough to bolt the thing together,..... but I'll have to have my machinist make the proper spacers when I go to see him next week.
So,..the rear end is basically done. Save for (4) 1/4" spacers.
On Friday, I took the subframe connectors that I've had made for 8 months, and painted them in a titanium finish. The floor of the car has been clean enough for paint for a couple of weeks, so I painted the floor from the firewall back to right in front of the axle in a truck bed coating.
Since these subframe connectors have an integral jacking rail that welds into the rocker molding, I had to mock the thing up after it dried to be sure to transfer the weld areas over to the subframe connectors
All of those ground off areas you see are where I drilled holes through the floor, and the rocker pinch weld so that I could rosette weld the jacking rail to my car.
Then I laid on my back, and got my ass burned up while molten balls of galvanized sheetmetal dripped down from above.
The pic shows one done, and the other positioned and tacked. I just got tired of the smoke, the dirt, and the fire. I'll finish the other tommorrow.
The last thing I was able to get to was the intake. I had all of RD's fins fabricated, and welded in place, and Ricks fuel rail came in last night. So, before I close the garage, I fabricate the stand offs to hold ricks fuel rail, then, spray the whole thing in a wrinkle finish paint that has to be heat cured to make it solvent resistant. After one hour in the oven, and another spent cooling it down,..I broke out my DA, and sanded the paint off the top of RD's fins. Then cleared the top (because RD's fins are made out of 1/4" mild steel) and didn't want them to rust. Then put the thing together for the photo.
So tomorrow, ( if the wife will let me in the garage) I'll build the mount for the fuel system (that I have), and seal the tank in the Red Kote I used on the last project, and paint the floor from the axle back.
