- May 30, 2009
- 112
- 9
- 16
Clean WA title tags i own this car.<br>
Please no day dreamers. Will consider partial trades. any questions email. Testing be for it hits ebay.
The car is in vancouver wa
<br>
Video Link YouTube - twin turbo mustang‏
1992 ford mustang lx 5.0
Runs Drives Asking $8500 Cash Open To Part Trade And Cash saleing to pay tickets
Saleen Body Kit With Wing Black
Out Kit
Cobra RR Hood
Cobra Grill
00 Cobra Wheels Front 225/45/17 Rear 245/40/17
Engine 5.0 302 v8 Rebuilt specs
TRW Forged Pistons
Piston Rings, Plasma-Molly
Melling M-68HV - Melling High-Volume Oil Pump with Hardened Driveshaft Clevite Cam, Rod, Main Bearings
E303 - Ford Racing Camshaft Duration 282/282, Lift .498/.498 Ford Racing Timing Chain and Gear Set, Double Roller, Iron Sprockets
GT40 Intake
GT40p Heads
9333 Felpro Head Gaskets
ac/somg delete
Ford Racing 24# High Flow Fuel Injectors
Aeromotive Ford Fuel Pressure Regulator with gage Boost/Vacuum Rise Ratio1:1
BBK Throttle Body, 70mm
C&L Maf 73mm Set 24# and cobra ecu 93 Cobra ECU
MSD 6A Ignition and Coil
Twin Turbos t3/t4 5-20 psi
Blow off valve
Intercooler
3 inch custom exhaust with x pipe flow masters Shorty Headers 1-5/8 fits Gt40P heads
Optima Red Top Performance Battery
3G Alternator Swap
Auto meter gages
Suspension
94 Mustang Spindles
Adjustable Brake Prop Valve
PRB 2 Piston Caliper's
94 Mustang Disc Brake Rear End Ford Racing 373 Gears
Ford Racing Ebrake cables
Ford Racing Clutch Cable, with Aluminum Quadrant, Adjustable
Stock t-5
Pro 5.0 shifter B&M shift handle with line lock
Energy Suspension Master Bushing Kit
Energy Suspension Motor Mounts and Trans Mount
Centerforce Dual Friction Clutch
Ford Racing Aluminum Driveshaft
Drive line Hoop
Maximum Motorsports Full Length Subframe Connectors
Eibach Springs
Bolted and welded torque boxes
Lakewood Heavy Duty Rear Upper Control Arms
Lakewood Heavy Duty Rear Lower Control Arms
<br>
Out Kit
Cobra RR Hood
Cobra Grill
TRW Forged Pistons
GT40 Intake
GT40p Heads
ac/somg delete
Blow off valve
Intercooler
3G Alternator Swap
Auto meter gages
Suspension
94 Mustang Spindles
Stock t-5
Drive line Hoop
Eibach Springs
