As stated: 1996 Cobra, cranks, fired one time and sounded terrible for 1/2 a second. Then nothing. Just cranks.
I just bought the car, the PO thought the engine was blew (said a compression check said #5 had low compression) but even with that, the engine should still run, so there is another issue. From what I understand 3-4 years ago when it broke he was a bit tipsy and was doing donuts in a field when it died. He had replaced the fuel filter and that's about all the I know. We went in today and put new plugs in it and hooked everything back up as well as a new belt and battery.
From what I can tell nothing has come unplugged, the fuel safety switch in the trk (what ever that thing is called) is not tripped. It has 35-45lbs of fp when cranking at the rail. So we have fuel.
It has air unless the maf is dead... not as likely as the below.
My only guess is a bad coil pack or multiple bad wires. Any thoughts?
I have not hooked a obdII scanner up to it yet but I would think since the battery was left dead for so long that any prior codes would no longer be there.
