- May 27, 2008
- 5
- 0
- 0
I need some serious help. It's a long story, but I will make it as short as I can.
I have a 98 GT, automatic, minor mods, nothing serious, and I do not have torque converter lockup after overdrive. I took it to the local Ford dealer, and they told me to replace the whole transmission ??? ($2500 bucks) . Anyway I did not like their answer (they charged me 100 bucks to look at it) Then I took it to a well known transmission repair shop. The owner of the shop hooked a computer to the connection under the dash and drove away. The car goes through all 4 forward gears no problem, has reverse and park as well. Shifts smoothly, but won't kick down after I reach cruising speed.
Transmission guy tells me there is nothing wrong with transmission???? His laptop computer shows that the PCM is not asking for lock up to the torque converter. All the sensors are working withing normal parameters. He showed me on the laptop that there was 0% asking for lockup to the torque converter. Man - O - Live batman.... He tells me to start checking the PCM by disconnecting low voltage sensor wires.
I take the car home, run it, and start disconnecting electrical sensors, hoping for a check engine light to appear. Nothing, no light. (it comes on when you put the key in and turn it to start the engine). I disconnect the coolant sensor figuring this will definitly work, but the electric fan comes on, and the check engine light stays off. I then figure that I will disconnect the Idle Bypass wire and this will definitly throw a light. Nothing, except the car almost dies so I recconect the wire before it does.
It is my understanding that the PCM does not tell on itself when it takes a crap. It will tell on everything else, but it will plead the 5th when it comes to itself. I don't want to buy a new PCM and have it not be the problem, and I am afraid to take it back to the dealer who will rip me off for another 100 bucks. notnice:
Any suggestions?? Anyone have this problem before?? Your help is greatly appreciated. Thanks in advance.
