Hey Everybody,
I'm currently undergoing the process of acquiring all the parts to do a full engine swap in my '03 coupe. I plan on going with the 3.55:1 gears in an 8.8" rear. A tremec tko500 trans with a centerforce df700000 clutch kit. The 351w is where I am having the problems. I know that an AJE tubular k member is in order as well as various other parts to make a efi to carb swap. I want at least 450hp at the flywheel, can anyone suggest a reasonable way to achieve this goal? If so I need part numbers and measurements as to how you would get there/how you have gotten there. I have read a lot of feeds in which others have tried this same swap. I didn't like the numbers they were getting and thought they might have done a crap build. I've got about 4,000 investible dollars to go toward this engine and just need help to get the most power for my money. Thank you for your help.
