2012 6r80 not moving car
cmorris96
Memphis
We have a test car, 2012 Gt auto, that's had intermittent problems- you could drive it and it would randomly stop holding gear, almost like the converter is slipping. Leave for the night and the next day it would be fine. Not temperature dependent from what I understand, completely random. It has an aftermarket, higher stall converter and is tune corrected for that. We did some chassis dyno testing with nitrous to test converter lockup, and it all went well no random trans problems. Converter lockup clutch was fried (which is what we were trying to do for the test) so it was pulled to install a new one. While the tranny was out, we sent it off to get looked at/rebuilt/tested. Got everything back and installed with new converter and fresh trans, same problem- only this time it's staying. To move it around the shop you have to rev it to at least 4k for it to even begin to move under it's own power, and get a pretty good running start to even think about driving up onto the 4 post lift. With data logging, you can see the pressures are good in gear as well as being able to "feel" it go into gear. It feels as if the converter isn't getting fluid almost (second converter, same problem). Thought maybe it could be the trans leadframe issue I've read about causing it to start in 5th gear, but it does it in reverse also so I have my doubts. Any ideas? Maybe a wire has been pinched taking the tranny in and out a couple times, or moving the harness around loosened something? I know the TC fluid pressure is all internal probably but I have abosutely no idea what to check out next.
  • Sponsors(?)
Thread starter Similar threads Forum Replies Date
G leaking 6r80 tansmission 2012 gt 2010 - 2014 Specific Tech 2
91StangGT5.0 2012 Mustang 6-Speed Manual to Auto (6R80) swap 2005 - 2014 S-197 Mustang -General/Talk- 4
D Engine 2012 GT, blown engine 2010 - 2014 Specific Tech 3
R 2012 mustang stock headlights 2005 - 2014 S-197 Mustang -General/Talk- 3
C For Sale FS: 2012 Mustang GT - 73k - White/Grey - NOLA - $15,500 S197 Mustangs For Sale (2005-14) 1
1990gsp SOLD FOR SALE / 2012 (Kona Blue) Mustang GT Premium / Atlanta GA S197 Mustangs For Sale (2005-14) 3
B P0024 Timing Over Advanced; 2012 Ford 5.0 Coyote 2005 - 2014 S-197 Mustang -General/Talk- 9
4 Digital Tuning Backup Tune for 2012 Mustang GT, Computer Code ZFK0 2010 - 2014 Specific Tech 0
D Speed shifting from 1st-2nd-3rd grinds and reverse guard/lockout broken? 2005 - 2014 S-197 Mustang -General/Talk- 0
2 2012 mustang gt Miles till empty reading incorrect 2010 - 2014 Specific Tech 0
8 Suspension 2012 8.8 Swap Fox 5.0 Mustang Tech 8
R 2012 Mustang GT Hurst Shifter 2010 - 2014 Specific Tech 2
M 2012 convertible power seat switch 2005 - 2014 S-197 Mustang -General/Talk- 0
L 2012 V6 Transmission Recall 2005 - 2014 Specific V6 Tech 0
A 2012 Mustang GT help 2005 - 2014 S-197 Mustang -General/Talk- 1
R For Sale Spare Tire and Wheel 2012 Mustang V6 Wheels Tires Brakes 0
N 2012 Misfire 2010 - 2014 Specific Tech 4
S Brakes 2012 V6 serious ABS issue or ???? 2005 - 2014 Specific V6 Tech 0
P 2012 V6 remote key problems 2005 - 2014 S-197 Mustang -General/Talk- 0
X 2012 Mustang GT/CS 19x10 square setup question about sway bar link bolts 2010 - 2014 Specific Tech 3
J For Sale 2012 Roush RS3 for sale / $37,698, San Diego, CA. S197 Mustangs For Sale (2005-14) 0
M 2012 V6 rear diff/axil whine only while turning 2005 - 2014 S-197 Mustang -General/Talk- 2
S1lv3rBull3t 2012 Mustang GT exhuast Clip 2005 - 2014 S-197 Mustang -General/Talk- 1
T 2012 V6- OEM Blower Motor (fan) making weird noise 2005 - 2014 Specific V6 Tech 0
J Engine 2012 mustang GT MISFIRE 2010 - 2014 Specific Tech 1
2012-5SLOW 2012 5.0 gauge cluster 2010 - 2014 Specific Tech 0
G For Sale $$$ 2012 GRABBER BLUE GT 5.O FOR SALE $$$ S197 Mustangs For Sale (2005-14) 0
robsball Electrical 2012 GT Convertible Drain on battery - Suspect Trunk component 2010 - 2014 Specific Tech 0
D 2012 EPAS Power Steering Unit Replacement Tips & Tricks 2005 - 2014 S-197 Mustang -General/Talk- 1
2012-5SLOW 2012 5.0 taillights 2010 - 2014 Specific Tech 3
2012-5SLOW 2012 5.0 burning oil 2010 - 2014 Specific Tech 7
Fomoco1649 For Sale 2012 Gt/CS. Factory wheels Wheels Tires Brakes 1
I Drivetrain 2012 V6 Manual Transmission Swap 2005 - 2014 Specific V6 Tech 1
B 2012 GT grille swap to a 2012 V6 2010 - 2014 Specific Tech 0
D Progress Thread 2012 Boss 302 Wheels on a 2008 Mustang GT 2005 - 2014 S-197 Mustang -General/Talk- 1
D 2012 windshield wipers only work on high speed 2010 - 2014 Specific Tech 2
2 Paint and Body 2012 Gt wheels on a 2001 GT? 1996 - 2004 SN95 Mustang -General/Talk- 4
B 2012 V6 Mustang dies and won't restart until cooled 2005 - 2014 Specific V6 Tech 0
B 2012 Mustang AC Leak 2005 - 2014 S-197 Mustang -General/Talk- 1
K Opinions on a 2012 mustang v6 i'm looking to buy 2005 - 2014 S-197 Mustang -General/Talk- 4
C For Sale 2012 GT / 47, 600K Miles / Lots of Upgrades, Houston, TX ($19,500 OBO) S197 Mustangs For Sale (2005-14) 0
Winters98GT For Sale 2012 Pristine Coyote Fs S197 Mustangs For Sale (2005-14) 0
J Help- 2012 Ford Mustang Stuck In Deforst Mode - Blows Hot Air 2010 - 2014 Specific Tech 2
R 2012 Convertible - Plug Under Rear Seat? 2005 - 2014 S-197 Mustang -General/Talk- 0
S Rear Sway Bar / Ride Height Imbalance 2012... 2010 - 2014 Specific Tech 1
E Mustang 2011-2014 80,000+ Miles? 2010 - 2014 Specific Tech 1
Tootzilla Looking For Wheel Recommendations (12' Gt) 2005 - 2014 S-197 Mustang -General/Talk- 3
F 2012 Gt Audio Mustang Sound & Shine All 0
C Expired Winter Wheels Set Off My 2012 Gt. Located In Connecticut Wheels Tires Brakes 0
deadmilenko Expired 2012 Gt 18" Oem Wheels W/tpms Wheels Tires Brakes 4
