Sounds fair.
What I currently have: 70mm tb (from other threads I've heard this flows enough) haven't checked what my MAF is.
Mishimoto radiator
130 amp 3G upgrade
Electric fan and control pack
Haven't looked if there is subframe connectors and don't think the rear end has been messed with. Just lowering springs I think.
What I was planning on using:
Fordstrokers 347 fox bottom end built liberator- $3500
Trick flow 190 heads (also on fordstroker)- $2000
Custom cam (don't know anything about them) -~$300
Trickflow r series intake- $700
24# injectors no specific brand in mind
Probably better fuel rail?
Other than that I don't know about exhaust, trans, clutch flywheel, water pump?? etc. that's what I'm tring to figure out, how much this stuff I don't know about will cost.
Current condition is I'm about to do a gasket change. It's leaking from head bolts, timing cover and intake. Runs good other than that. Trans probably needs to be replaced as going into 2nd isn't smooth and gotta fight it to get into reverse sometimes.
A5literman, thanks for the ball park figure. Whew, so a ten k motor figure 3-5k in labor? How much does an exhaust headers to mufflers normally run to put in figuring name brand?
