W WhiteCobra88 New Member Aug 15, 2004 4 0 0 Nov 30, 2004 #1 Nov 30, 2004 #1 Can anyone tell me if the trickflow twisted wedge heads will fit on ford's 347 stroker block assembly
D Daggar New Member Jul 19, 2004 3,902 5 0 Nov 30, 2004 #2 Nov 30, 2004 #2 Yes they will. If the pistons are flycut then p to v clearance shouldn't be an issue but as always, should be checked. If the pistons are not flycut (I doubt that that's the case) then you're restricted on the lift and duration of the cam.
