351W stalls at traffic lights
Jaha95
15
Vejle > Danmark
Hi guys!
Ive got a 69 351w with FMX tranny and every time i take og for a drive og Will stall on me.
I can stop at a traffic light and after 5-10 seconds the rpm will drop from 700 to 250 and then stall.
If im quickly i han put in Neutral and keep it Running.
Ive also noticed that when i go from park to Drive, the car tries to jump forward
Can it be my converter in the way out?
Current things checked:
Oil level on the transmission
Aluminium radiator mounted (the coolant temp was a bit too high for me)
Rebuild carburator
New fuel pump
Checked timing and set to 10 degrees
New plugs gapped to 0.030
Oh and the current setup
0.30 over bore
Ported heads
Edelbrock 600cfm carb
Edelbrock rpm intake
Pertronix flame Thrower coil
Pertronix ignitor 3
Lunati barebones 280/290
Holley high flow mechanical fuel pump
Hooker headers
  • Sponsors(?)
DBegley
39
69
My 68 302 does that especially when it first gets started up. I think its a carb issue. My car is a 4 speed so I can control the idle with the clutch in. I put a new Holley carb in last summer. Been tweaking the settings but would like someone that knows carbs better than me check it.
7991LXnSHO
Now I want a 10 year badge
2,991
543
154
Kearney, NE
I do not know the carb make and model, so this will be general advice. The idle circuit might be partially clogged, and the idle mixture screws could need adjusted. After those issues are addressed, the idle speed screw should need adjusted.
  • PlusOne
Reactions: 2Blue2
2Blue2
will be trying this sex one when I can find it
Mar 5, 2019
2,294
1,385
133
53
Oahu
yes that is most likely
and or dirty fuel filter. Old car with old tank and lines? Tank not venting properly. Vac leak.
This carb not as picky as a holley when it comes to dirt but still can happen.
7991LXnSHO
2,991
543
154
Kearney, NE
I skipped that line about the carb. Yes, vacuum leaks are also a common cause of idle issues. Check the base gasket and any caps, too. Does this transmission have a vacuum line to a regulator?
Jaha95
15
Vejle > Danmark
Its an edelbrock 1405 600cfm
Ive already har the carb apart for a rebuild, so i dont Think the carb is clogged
Ive tried setting the idle screws to 2,5 turns out and adjusting in for the maximum vacuum and ends at about 2 turns.
Am i Going too lean?
Fuel filter has been changed, same goes for the lines, so i dont believe that fault is there
Ive just tried a vacuum meter on the inlet of the carb to check the vacuum, im Running About 14 Hg, when in drive, is it too low?
Ive just tried to change intake + carb gasket and no change
When you sat Line to regulator?
I have a Line Running from a T-piece in the intake to the tranny?
Ill try to have Another look after a vacuum leak
Thread starter Similar threads Forum Replies Date
Smcin For Sale 79 Mustang Ghia 351W swap project Fox Body Mustangs For Sale (1979-93) 0
mustangpauly 351w swap need help will not idle Digital Self-tuning Forum 8
B Had a 91 mustang GT for a while now and can't seem to figure out what to put in it or leave it stock Im thinking of a 351w to put in it any ideas The Welcome Wagon 1
S 460 vs 351w in the SN95 budget. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
B Anyone done the 351W swap? I need some info. 1996 - 2004 SN95 Mustang -General/Talk- 1
R Engine Who should I go with for a new 351W and manual trans Fox 5.0 Mustang Tech 2
ClevelandTim Progress Thread 351W 4FTE Build Part 1 & Part 2 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
860 Fox Forced Induction 351W fox going to On3 kit looking for suggestions Fox 5.0 Mustang Tech 6
Ultra90GT For Sale 351w GT40 tubular intake + extras Engine and Power Adder 0
J 351w wont start after cam swap 1965 - 1973 Classic Mustangs -General/Talk- 13
J 351w swap 02 mustang gt 1996 - 2004 SN95 Mustang -General/Talk- 2
J Cam for 69 351W 1965 - 1973 Classic Mustangs -General/Talk- 1
N 351w wide headers Fox Engine Swaparoo 2
T 351w timing Fox 5.0 Mustang Tech 15
M 2004 3.8 to carb 351w gauge help 1996 - 2004 SN95 Mustang -General/Talk- 0
T 351w behind 4r70w 1996 - 2004 SN95 Mustang -General/Talk- 0
Hollywood_Vae Sn95 351w swap 1994 - 1995 Specific Tech 6
S Rear Axle and Stock Fan/Shroud help w/ 351w 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
G Engine 351w AC with/without March pulleys? Fox 5.0 Mustang Tech 4
X Spark plug gap on 351w Fox 5.0 Mustang Tech 6
ebowie 351w with Trick Flow 11r heads with BBK tuned headers in 1995 SN95GT fit ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
X 351w with 302 cam? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
G Fox 351W power depending on build question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
D 351w na build combo opinions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
B Timing not advancing Fox Engine Swaparoo 6
CrazyRobert 351w V8 Escorch Wagon with Mustang parts Fox Engine Swaparoo 41
G 351W KB Blowzilla 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
ClevelandTim Engine 351W - Std cam or Roller? Fox 5.0 Mustang Tech 4
C Engine 289 block / 351w heads Classic Mustang Specific Tech 3
M I need help with my 351w project's ventalation Classic Mustang Specific Tech 6
M Estimated horsepower - stroked 351w? Classic Mustang Specific Tech 8
G Engine 351W coolant drip Fox 5.0 Mustang Tech 1
6 351w bronco Fox Engine Swaparoo 3
J 351w Rebuild - Looking for Guidance Classic Mustang Specific Tech 1
ndfox92 Fox does anyone have a victor efi intake for a 351w they want to part with? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
J Want to possibly swap out a 302 for a 351W Fox Engine Swaparoo 1
7 Engine 351W year to year changes? 1974 - 1978 Mustang II Talk & Tech 5
8 Engine 302 block with a 355 stroker, would these internals work in a 351w Fox 5.0 Mustang Tech 1
G 351W ignition "blip" or miss at 3500rpm or so Fox 5.0 Mustang Tech 10
Y sn95 351w Digital Self-tuning Forum 3
a91what 351w swap headers 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
James K Progress Thread 351w build and swap Fox 5.0 Mustang Tech 15
C For Sale Sold - 1988 Mustang GT - DSS Racing 351W - Price Drop!! - $4,000 Fox Body Mustangs For Sale (1979-93) 2
X 351w sn95 timing cover 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
Cobbage_45 Transition to Arizona with 351w Swapped Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
G Electrical A/C for 351W swap Fox 5.0 Mustang Tech 3
M 351w 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
M I think I blew a hole in my timing cover 351w, help needed 1965 - 1973 Classic Mustangs -General/Talk- 2
S Fuel 1992 351w Swap Fuel Pressure Issue/problems - Please Help! Fox 5.0 Mustang Tech 13
Driver460sz 86 fox 351w (427) project 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
