I also have done the 351W swap.
btw,nice times there 86bulecobra
you must really be rowing that shifter
My first time I built up a 357 (.030 over 351W),was a 74' block,stock crank (witch btw,I feel is fine to 500fwhp),stock rod with ARP bolts,KB hyper pistons,TFS Track heat heads,a Crane hydro roller cam,Victor Jr. intake,BG 750 Speed Demon,
BBk long tubes w/ a 2.5' h-pipe and
flowmaster 2 chambers.The motor was backed by a POS C4 with trans break,and a good PTC 10" converter.It had 3.73 gears and was on 26"X10.5" M/T ET Drags.
On slicks,it ran a 7.03 @ 100mph in the 1/8 mile with a 1.53 60' time.That was on a 125hp shot NOS plate,it would have gonna into the 6's if it wasnt for the C4 slipping in every damn gear!
And that is some were around a 11 flat if not a 10.90 run in the 1/4!
Of course,the strokers are awsome,our 408 goes faster than the 357 did on the bottle!
As for blocks fyi,the older one are best as far as strength (69'-74'),but if you plan on a roller cam you got to either get the valley spider,or better yet the retro-fit lifters (we are using Crane,great hyd. roller lifters).
