I have a 2001 Ford Mustang Gt and I'm having 5 issues with it. Not sure if they are related or not. Kind of lost and not sure what I should spend money on fixing first.
1) The car takes a few times to start, sometimes it will start and die immediately but the lights on the dash stay lit up.
2) Car sputters at low rpms when I give it gas, drives fine otherwise.
3) I smell gas while I'm driving
4) Had alternator checked and has a bad diode but the lights don't seem to dim and battery is good
5) check engine light is on and had it scanned and the codes came back as the following.. P0113 air intake temperature circuit high input, P0340 Camshaft Position Sensor "A" Circuit (bank 1 or single sensor), P0130 O2 Sensor Heat Circuit (Bank 1 Sensor), Code P1639 Vehicle ID Block Not Programmed Or Corrupt (Ford)
Thanks
Thanks
