85 towncar MC is a 1" bore MC...same as 1993 Cobra MC.
If this is on an 87+ Mustang it's a PITA as none of the fittings interchange and you'll need all adapters and/or custom lines. The 85/85 PV does have the 3rd fitting at the rear, so it makes an easy 3-2 conversion...but a SN95 fitting does the same thing and no need for any funky adapters.
What exactly do you want to accomplish? There are tried and true setups plenty of guys run. If you want a firm pedal, just upside the MC a 1/16". But the pedal feel depends heavily on the calipers mounted on the car. If you have different calipers, a certain MC won't give you the same feel as another setup. The MC doesn't dictate the feel...the hydraulic ratio of the master and calipers as well as booster assist does. But there are literally dozens of combinations of calipers/mc/booster setups to run.
