408 stroker.Need Carb input.
pnswann25
AZ
Need some help with carburetor recommendations. Just completed a 408 stroker motor. Block is a 69 351W with a stroker kit from coast high performance. Heads are TFS 64CC CNC Chamber. Cam specs are Intake 359@valve:574 lift Exhaust 372@valve 595. I currently have an edelbrock 750 carb, but my car bogs down when pulling off in first gear. I have a 5-speed tranny.
Double pumper or vacuum?
there is a cam thing on the linkage that works the squirters, with the engine off, look down into the front part of the carb and move the linkage a little and see if it squirts fuel.
i'm sure there are some members here that use carbs still, it a process to tune one, make sure your power valve is good, float levels are correct.
is it new or used?
Oh, Rue Paul is a tranny, t5 is a trans or transmission, just say'n. :jester:
