i have a 5.0 with roush 200 heads,trick flow track heat intake,bbk 75mm throttle body,adjustable fuel regulator,stock ignition system,75mm mass air.
my problem is the fuel system was stock and it started to break up at 4000 rpm and back fire through intake so i up grade throttle body and regulator and fuel pump. the problem is still there, so i changed distributor cap and have adjusted fuel pressure. im out of ideas and i no nothing about fuel injection please some one give me ideas.
